2014-08-23 by rpcfender@...
Have you used MidiOx to send sysex in XP and can't get it to work in Win7 or have you not used MidiOx before?
In case of the latter....
Set up MidiOx by selecting the BCF midi in and out ports by going to Options/Midi Devices.
Make sure you have the Input and Output Monitor windows open as well as the Midi Port Routing window (under the View menu)
Left click drag a connection from the MidOx Event Port on the Routing window to your BCF port on the right.
Select Options / Pass Sysex
NOTE that sometimes this needs to be de-selected and then reselected.
Don't know why. I have asked Jamie, but he is a busy fellow.
Open the Sysex window by View / Sysex.. menu.
On this new window use File /Send Sysex File.
Select the file and the sysex should be sent to the BCF and you should see the sysex in the Output Monitor .
All the best
Royce
