I just had one die in a 2 bcr2000 carry 'round flight case.I thought "Oh no I re-capped that one - what now!?Thanks for the cross-ref data foot work for us. I'' try that is it's not the caps again. I used 6.5v caps cause that's what I had. - I'll get my coat.
From: "dave_evans2200@... [bc2000]" <bc2000@yahoogroups.com>
To: bc2000@yahoogroups.com
Sent: Friday, July 17, 2015 2:32 PM
Subject: [bc2000] BCF power supply repair success story
New member here.I've just done a successful repair on my BCF power supply.The main switch mode chip TNY268P had failed, got a replacement (actually a TNY268PN) on eBay for £2.30 (UK price), soldered it in, success! I'd already checked the capacitors, but they were all OK. This is a fairly simple repair if you have soldering experience or you could get a tech to do it for you. Be very careful of the high voltages on the PSU board when testing!The PSU 7 pin connector should have the following voltages on it: 3 pins at 0v, 3 pins at 5.4v, 1 pin at 4.9v (the one with the red wire).Hope this helps someone fix theirs. I don't have the schematic, but it's a mixture of the TNY268 data sheet and the TL431 data sheet, both available online, as are a couple of guides to opening the unit up and dismantling it.Good luck! #yiv2665627083 #yiv2665627083 -- #yiv2665627083ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv2665627083 #yiv2665627083ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv2665627083 #yiv2665627083ygrp-mkp #yiv2665627083hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv2665627083 #yiv2665627083ygrp-mkp #yiv2665627083ads {margin-bottom:10px;}#yiv2665627083 #yiv2665627083ygrp-mkp .yiv2665627083ad {padding:0 0;}#yiv2665627083 #yiv2665627083ygrp-mkp .yiv2665627083ad p {margin:0;}#yiv2665627083 #yiv2665627083ygrp-mkp .yiv2665627083ad a {color:#0000ff;text-decoration:none;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ygrp-lc {font-family:Arial;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ygrp-lc #yiv2665627083hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ygrp-lc .yiv2665627083ad {margin-bottom:10px;padding:0 0;}#yiv2665627083 #yiv2665627083actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv2665627083 #yiv2665627083activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv2665627083 #yiv2665627083activity span {font-weight:700;}#yiv2665627083 #yiv2665627083activity span:first-child {text-transform:uppercase;}#yiv2665627083 #yiv2665627083activity span a {color:#5085b6;text-decoration:none;}#yiv2665627083 #yiv2665627083activity span span {color:#ff7900;}#yiv2665627083 #yiv2665627083activity span .yiv2665627083underline {text-decoration:underline;}#yiv2665627083 .yiv2665627083attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv2665627083 .yiv2665627083attach div a {text-decoration:none;}#yiv2665627083 .yiv2665627083attach img {border:none;padding-right:5px;}#yiv2665627083 .yiv2665627083attach label {display:block;margin-bottom:5px;}#yiv2665627083 .yiv2665627083attach label a {text-decoration:none;}#yiv2665627083 blockquote {margin:0 0 0 4px;}#yiv2665627083 .yiv2665627083bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv2665627083 .yiv2665627083bold a {text-decoration:none;}#yiv2665627083 dd.yiv2665627083last p a {font-family:Verdana;font-weight:700;}#yiv2665627083 dd.yiv2665627083last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv2665627083 dd.yiv2665627083last p span.yiv2665627083yshortcuts {margin-right:0;}#yiv2665627083 div.yiv2665627083attach-table div div a {text-decoration:none;}#yiv2665627083 div.yiv2665627083attach-table {width:400px;}#yiv2665627083 div.yiv2665627083file-title a, #yiv2665627083 div.yiv2665627083file-title a:active, #yiv2665627083 div.yiv2665627083file-title a:hover, #yiv2665627083 div.yiv2665627083file-title a:visited {text-decoration:none;}#yiv2665627083 div.yiv2665627083photo-title a, #yiv2665627083 div.yiv2665627083photo-title a:active, #yiv2665627083 div.yiv2665627083photo-title a:hover, #yiv2665627083 div.yiv2665627083photo-title a:visited {text-decoration:none;}#yiv2665627083 div#yiv2665627083ygrp-mlmsg #yiv2665627083ygrp-msg p a span.yiv2665627083yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv2665627083 .yiv2665627083green {color:#628c2a;}#yiv2665627083 .yiv2665627083MsoNormal {margin:0 0 0 0;}#yiv2665627083 o {font-size:0;}#yiv2665627083 #yiv2665627083photos div {float:left;width:72px;}#yiv2665627083 #yiv2665627083photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv2665627083 #yiv2665627083photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv2665627083 #yiv2665627083reco-category {font-size:77%;}#yiv2665627083 #yiv2665627083reco-desc {font-size:77%;}#yiv2665627083 .yiv2665627083replbq {margin:4px;}#yiv2665627083 #yiv2665627083ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv2665627083 #yiv2665627083ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv2665627083 #yiv2665627083ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv2665627083 #yiv2665627083ygrp-mlmsg select, #yiv2665627083 input, #yiv2665627083 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv2665627083 #yiv2665627083ygrp-mlmsg pre, #yiv2665627083 code {font:115% monospace;}#yiv2665627083 #yiv2665627083ygrp-mlmsg * {line-height:1.22em;}#yiv2665627083 #yiv2665627083ygrp-mlmsg #yiv2665627083logo {padding-bottom:10px;}#yiv2665627083 #yiv2665627083ygrp-msg p a {font-family:Verdana;}#yiv2665627083 #yiv2665627083ygrp-msg p#yiv2665627083attach-count span {color:#1E66AE;font-weight:700;}#yiv2665627083 #yiv2665627083ygrp-reco #yiv2665627083reco-head {color:#ff7900;font-weight:700;}#yiv2665627083 #yiv2665627083ygrp-reco {margin-bottom:20px;padding:0px;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ov li a {font-size:130%;text-decoration:none;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv2665627083 #yiv2665627083ygrp-sponsor #yiv2665627083ov ul {margin:0;padding:0 0 0 8px;}#yiv2665627083 #yiv2665627083ygrp-text {font-family:Georgia;}#yiv2665627083 #yiv2665627083ygrp-text p {margin:0 0 1em 0;}#yiv2665627083 #yiv2665627083ygrp-text tt {font-size:120%;}#yiv2665627083 #yiv2665627083ygrp-vital ul li:last-child {border-right:none !important;}#yiv2665627083
