Cgs synth
Some small ASR problems
2007-01-05 by Louis van Dompselaar
Hi list,
I'm running into some small problems with my ASR. It is working as it
should, apart from two things:
First, the LF356 are running warm, which usually only troubles me if the
circuit doesn't work either. Should they get warm if it works fine?
Second, the outputs step up and down by around 10mV in sync with pin 12 of the 4024.
With no input, it steps between 90mV and 100mV.
This stops if I pull out the clock, so it's not coming in through the
power rails. This pcb trace is pretty small and I can't see anything
wrong along it. Anyone ever seen this before? How can this signal
get into the outputs?
When the clock is off, the outputs are rock solid. No drooping whatsover,
it can hold the input seemingly forever. I got some big bright yellow
polypropylene capacitors off eBay that work great. It turned out to
be quite hard to get decent sized 47nF polypropylene over here...
Louis
Re: Some small ASR problems
2007-01-05 by sasami@hotkey.net.au
It's not right.
I would not expect them to get warm.
the 4024.
I suspect it is a power rail issue, but on this PCB only. Did you use beads
or 10R resistors as power rail isolation? If you used the resistors, try
shorting them out. Increase power rail decoupling. Check your power rail
voltages. It sounds like the LF356 are are drawing too much power for some
reason. Not a bad batch per chance?
Ken
_______________________________________________________________________
Ken Stone sasami@...
Modular Synth PCBs for sale <http://www.blaze.net.au/~sasami/synth/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
2007-01-05 by Richard Brewster
A modification recommended in the Notes is to add a 100 ohm resistor
between pin 1 of TL074d and pin 3 of 4052. This was suggested if you
use a larger capacitor for CX. I used 100nf caps and did add the 100R.
Note: These are special 100nf caps, WIMA mixed film type, Mouser #
MKP2-.1/250/5
I also added 100nf bypass caps on the two power pins of the TL071 that
buffers the clock input. That should help protect against the clock
feeding back into the power supply.
Richard Brewster
http://www.pugix.com
Louis van Dompselaar wrote:
> Hi list,
> Louis
> The CGS Modular Synth home page: http://www.cgs.synth.net/
2007-01-06 by Louis van Dompselaar
> Did you use beads
Ferrite beads, but the ones where the wire goes through the bead
multiple times. I have some plain ones lying around that I could use.
I've ordered some new ones just to make sure.
Louis
2007-01-06 by Fernando de Izuzquiza
I found the ferrite beads at RS Components in Europe.
I've added the RS part number, manufacturer (Murata) part number and RS link at this
group's links page.
You can find it from other suppliers if you find them in their catalog (not easy)
Fernando
> > Did you use beads
> Louis
2007-06-03 by peng3002
I'm having the EXACT same problem as described in the post below.
Louis, did you fix the problem? I tried the suggestions in the
follow-ups but they didn't help with this problem. I'm using LF356H
made by National with these markings: H24XX.
I'm putting it on the breadboard to see if I can work this out, but
if you (or someone) already has a fix...I'd love to here it! Also,
more suggestions and/or guesses would be helpful, too.
Note: I swapped the 4052 with another brand and got no change. The
LF356 are soldered in place so I haven't swapped them out yet. I only
have one make of the 4024 so I can't swap that yet.
p.
--- In cgs_synth@yahoogroups.com, Louis van Dompselaar <louis@...> wrote:
> Hi list,
12 of the 4024.
> power rails. How can this signal
> Louis
2007-06-04 by sasami@hotkey.net.au
It may not be coming in through the power rails from outside, but rather
being introduced onto the power rails by the 4024 itself. The first thing to
do is to solder a 10uf to 100uf electro directly across the power pins of
the 4024. If this helps, disconnect pin 14 the 4024 from the positive rail,
and add 10 ohms between the power rail and pin 14. The added caps should
remain directly between pins 7 and 14.
Ken
>Thanks,
>p.
>> Hi list,
>12 of the 4024.
>> Louis
>Yahoo! Groups Links
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
2007-06-04 by John Mahoney
>the 4024. ...
uF or nF?
john
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007 12:47 PM
uF. we are going for "driving tacks with a sledgehammer" approach here .
adding a 100nF in parallel with the 100uF wouldn't hurt either.
Ken
>>the 4024. ...
>uF or nF?
>john
12:47 PM
>Yahoo! Groups Links
