gated comparator "rev 1" - need mod?
2007-10-06 by loopcycle
2007-10-06 by sasami@hotkey.net.au
>I've just finished wiring my gated comparator and I've got problems.Current boards say "rev 1". I should make the text clearer. The mod is not
>I cant get past stage one--I get leds lit on stage one and the output.
>1. My board says "rev 1". Is this *not* the rev 1.1? (do i need the
>mod?)
>2. I'm using an LM358n on the board. I'm aware that a tl072 is aQuite possibly. It sounds like your clock signal is not getting through.
>better choice and I'll replace it if I need to.
2008-01-04 by loopcycle
>is not
> >mod?)
> needed.OK--I've finally replaced the LM358 with a TL072...and I still cant
> Also check you have your "sense" input set at an appropriate level.
> Ken
2008-01-04 by sasami@hotkey.net.au
>OK--I've finally replaced the LM358 with a TL072...and I still cant_______________________________________________________________________
>get past stage one--I get leds lit on stage one and the output only.
>I've tried different threshold level settings with the pot. Any help
>is appreciated--I'm just getting started with DIY and (particularly
>new to) troubleshooting. Thanks!
2008-01-05 by loopcycle
> The first thing you need is a way of seeing what is happening on the various____________________________________________________________________________________
> pins of the ICs. If you don't have a logic probe, run a cord from your VCO
> pitch input, connecting a 100k resistor to the tip of the cord (use an
> aligator clip), and use the other end of the resistor as your probe. The VCO
> and ther module you are trying to fix need to be running on the same PSU or
> have their 0V rails connected. The pitch of the oscillator will tell you
> what is happening at the pins. Don't think you can use a multimeter instead
> - their response is too slow.
> Now start at one side of the schematic, and work out what that part is meant
> to do. Make sure it is doing it. If not, fix it. When that works, move to
> the next bit!
> Ken
> Ken Stone sasami@...
> Modular Synth PCBs for sale <http://www.cgs.synth.net/>
> Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
> The CGS Modular Synth home page: http://www.cgs.synth.net/
2008-01-05 by sasami@hotkey.net.au
>ok, i found my happy stupid mistake...which also explains why ive had 100%:)
>failure rate on all my cgs diy projects until now. i forgot to put in my
>links!
