Cgs synth
CGS 121 Building question
2018-02-03 by mauro.tondini
Hi, i'm building the CGS 121 Quad comparator and Memory Cells, i have not muck space in my panel, so i would configure it with two comparators and the two cells as flip flops
For this configuration do you suggest to wire CLOCK and DATA or SET and RESET?
Also: which is the right value for the input balance potentiometer, 10k as in the schematics or 100k as in the BOM?
Thanks
Mauro
Re: CGS 121 Building question
2018-02-03 by cg_synth
Probably Clock and Data. All the same, you may find Set/Reset just as useful.
Balance pots are 100k in both the bom and the schematic.
2018-02-04 by mauro.tondini
Yes, sorry, the 10 k lin value is in the wiring diagram..
Thank you for the suggestion.
Cheers
