Crumar Symphonizer note issue
2008-12-01 by montamusic
Index last updated: 2026-04-28 23:17 UTC
Hi guys, I've got a Crumar Symphonizer and all of the G# notes have gone dead. Any idea how to fix it? It was working fine up until now. Thanks, dedric
2008-12-01 by rakky
Assuming that a Symphonizer uses organ-type divide-down technology (a la Polymoog), then this sounds like one of the boards (or chips) (the one controlling the G#s has passed away due to old age. You'll need schematics to work this out, then hopefully a simple board (or chip) replacement would sort it out. Assuming they are available. However, don't quote me on that! I may well be barking up the wrong tree. Or simply barking. I do however know someone who fixed a similar problem on a Polymoog by simply replacing the right chip. --- In crumar@yahoogroups.com, "montamusic" <dedricmoore@...> wrote: > > Hi guys, > > I've got a Crumar Symphonizer and all of the G# notes have gone dead.
> Any idea how to fix it? It was working fine up until now. > > Thanks, > dedric >
2008-12-07 by montamusic
Thanks for the tip. I found a guy here in Kansas City that worked on Crumars when they came to the States 30 years ago. I'm taking it to him next week. Cheers, Dedric --- In crumar@yahoogroups.com, "rakky" <pargroups@...> wrote: > > Assuming that a Symphonizer uses organ-type divide-down technology (a > la Polymoog), then this sounds like one of the boards (or chips) (the
> one controlling the G#s has passed away due to old age. > > You'll need schematics to work this out, then hopefully a simple > board (or chip) replacement would sort it out. Assuming they are > available. > > However, don't quote me on that! I may well be barking up the wrong > tree. Or simply barking. > > I do however know someone who fixed a similar problem on a Polymoog > by simply replacing the right chip. > > > > --- In crumar@yahoogroups.com, "montamusic" <dedricmoore@> wrote: > > > > Hi guys, > > > > I've got a Crumar Symphonizer and all of the G# notes have gone > dead. > > Any idea how to fix it? It was working fine up until now. > > > > Thanks, > > dedric > > >
2008-12-08 by Robert Weigel
--- In crumar@yahoogroups.com, "montamusic" <dedricmoore@...> wrote: > > Hi guys, > > I've got a Crumar Symphonizer and all of the G# notes have gone dead. > Any idea how to fix it? It was working fine up until now. > > Thanks, > dedric > Yeah I just worked on a symphonizer the other day and it's the earliest one I think Crumar made isn't it? Older looking design than the stringman etc. Anyway I think it uses a MK50242 TOS..I can't recall. Multiman has the MK50240 which is more common. I should have written more info on it while I had it here. I seem to recall the SAJ110 dividers but those would generally be bad if you were missing sub-octaves. If it's all the notes of a type them most likely the Top octave synth chip (TOS) or discrete oscillators in units that have 1 for each note (12). Like combo organs or the early Roland EP10 piano etc. But all the crumars used TOS chips I believe. -bob
PS and I should have said to trouble shoot you can use a headphone amp (nice because small and a volume control you can thumb operate as you are probing around often. I built a custom one for this purpose) and just hook a probe to a jack that goes into it. THen you can ground clip onto the ground of what you are working on and put the probe on various pins of the TOS for instance and you can hear all the frequencies there. If one is missing or distorted it should be obvious that you then have a bad TOS. -Bob
2008-12-09 by montamusic
Yes. It's an early model that was released here in the US, or so I'm told, that didn't do well and was discontinued. Mine is A/77. It's been invaluable on our last recording and I'd hate to lose it. I'll pass on the tips to the service guys. you've given me a much better understanding of how this thing works. Many thanks, Dedric --- In crumar@yahoogroups.com, "Robert Weigel" <sounddoctorin@...> wrote: > > --- In crumar@yahoogroups.com, "montamusic" <dedricmoore@> wrote: > > > > Hi guys, > > > > I've got a Crumar Symphonizer and all of the G# notes have gone dead. > > Any idea how to fix it? It was working fine up until now. > > > > Thanks, > > dedric > > > Yeah I just worked on a symphonizer the other day and it's the > earliest one I think Crumar made isn't it? Older looking design than > the stringman etc. Anyway I think it uses a MK50242 TOS..I can't > recall. Multiman has the MK50240 which is more common. I should have > written more info on it while I had it here. I seem to recall the > SAJ110 dividers but those would generally be bad if you were missing > sub-octaves. If it's all the notes of a type them most likely the Top > octave synth chip (TOS) or discrete oscillators in units that have 1 > for each note (12). Like combo organs or the early Roland EP10 piano > etc. But all the crumars used TOS chips I believe. -bob >
