Sv: Sv: [crumar] BIT 99 midi latency....
2000-11-17 by Søren Pedersen
Okay, you´ve tryied the audio buffer. A friebd of mine has the same problem. He use this little trick to solve the problem : Record the notes you want the VST instrument to play on a normal midi track with a similar sound from you keyboard. Then move the part to the VST instrument track and it will play back with no latency. Sloppy S Denmark ----- Original Message ----- From: Frédérique Durand <under99neons@...> To: <crumar@egroups.com> Sent: Thursday, November 16, 2000 11:55 PM Subject: Re: Sv: [crumar] BIT 99 midi latency.... Thanks for answering...and ....HI !!!! If u r talking about audio buffer...i ve tryed...no success....it's only by using Virtual VST instruments....i know than my sound card is really S..T !! But i think it can work !!!!! If somebody know another thing..... (may i m dumb... %-( ...) Gilles/paris --- In crumar@egroups.com, Søren Pedersen <studioz@g...> wrote: > Hi Gilles > > What do you mean by the audio response from Cubase ???? > Are you using an VST instrument ??? > If so then the latency problem will be you soundcard, set the buffer as low as you can. > > Sloppy S > Denmark > ----- Original Message ----- > From: <gillesdeshays@n...> > To: <crumar@egroups.com> > Sent: Wednesday, November 15, 2000 12:44 AM > Subject: [crumar] BIT 99 midi latency.... > > > > Hello to everybody here !!! > > > > I Got a BIT 99 since 3 years...working very very well... > > > > and i just try to use it as midi keyboard with cubase VST > > on a PII 233 64Mo Guillemot Maxi sound Home studio 2 > > and there is too many latency between the moment i play a note on the > > BIT 99 and the audio response of Cubase.... > > > > i think i've try all MIDI possibities of the BIT 99...and i just > > discover CUBASE...( i was on amiga and atari before..) > > > > Please HELP ME...i m losing hope....and i have many audio pieces to
> > remaster... > > > > .....PLEASE !!!!!!! > > > > THANKS!!!!! > > > > Gilles from PARIS/France > > > > > > > > > >
