adjusting midi files
2019-03-09 by Spencer Chase
Ian,
You mentioned boosting treble and cutting bass in midi files. No idea how you are doing this and if it is very labor intensive. I have a program called midi equalizer that lets you assign a scaling factor note by note. You can use a text file the same as you can in remap notes program etc. you could make various templates for common needs and save and use them when needed.
Best regards, Spencer Chase
67550 Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
Spencer@...
Spencer@...
Spencer@...
http://www.spencerserolls.com
http://www.poodlex.com
(425) 791-0309
(707) 223-8212
Re: Adjusting midi files for Disklavier
2019-03-10 by Ian
Thanks Spencer, for troubling to reply. I have long known of your useful programs, for PC, but I am exclusively Mac, so MidiSwing is what I use.
It is very intuitive in use. If I hit 'Command A' then click on centre of any highlighted note and hold the click and drag up or down screen a few millimeters, note velocities are increased or decreased proportionally over the entire file and to the degree I choose. I do it all 'live' to piano, by ear.
The good thing about the Window of the virtual piano roll that MidiSwing presents, is that the loudest notes are immediately discernible as they appear as a proportionally darker blue. Soft notes fade in colour to near invisibility.
I can do almost any other sort of adjustments as well – all in this one player/editor. Many midi files made during and before the 1990s have extremes of soft and loud, which do not play back well on modern solenoid pianos. A most useful 'add-on' for midis of that era would be an 'exponential' increase/decrease facility, (compared to the existing 'proportional') whereby the very softest notes exponentially increase in volume while the loudest barely change. This would render these old midis far more accurate to their intended playback – on our modern pianos. I'm guessing you would already have a program which does that.
I also shape the tempo line to alter phrasing of any midis to match the phrasing of any favourite pianist on audio performances from audio CDs, LPs or even Youtube performances. It is great to hear a 'live' performance played to match every nuance of an old 78 rpm disc, devoid of the sound of eggs & bacon frying above the piano music. You may agree if you play and compare the files I attached in my last email to this group.
Ian Williamson
On 10/03/2019, at 8:57 AM, 'Spencer Chase' lists@spencerserolls.com [disklavier] wrote:
Ian,
Garberville, CA 95542 Postal service only..
Spencer@...
Spencer@poodlex.com
Spencer@...
(425) 791-0309
(707) 223-8212
Re: [disklavier] Re: Adjusting midi files for Disklavier
2019-03-10 by Spencer Chase
all of my utilities (other than live MIDI playing programs, such as Virtual Pianola) will work in various virtualization environments. Mac users can use Boot Camp, VMware Fusion or Oracle Virtual Box. I use Virtual box on the PC to run Windows XP for programs that require it. Since it is likely that "security" changes to windows 10 will make it impossible to run many of my programs this will be a very useful option in the future. My midimod2 program allows you to create any velocity modification map that you want so you can do proportional, exponential or any other modification. None of my programs can fix errors such as missing pedaling or anything else that requires human editing but there are many systematic modifications that are a lot easier than editing by hand.
Spencer@...
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
------ Original Message ------
From: "Ian wam@... [disklavier]" <disklavier@yahoogroups.com>
Sent: 3/9/2019 5:06:14 PM
Subject: [disklavier] Re: Adjusting midi files for Disklavier
Ian Williamson
On 10/03/2019, at 8:57 AM, 'Spencer Chase' lists@... [disklavier] wrote:
Ian,
Garberville, CA 95542 Postal service only...
Spencer@...
Spencer@...
Spencer@mcn.org
(425) 791-0309
(707) 223-8212
