Playing imported midi files on disklavier
2006-10-08 by chadbot
Help please:
I've got a type 0 standard midi file from another source that was
recorded using Acoustic Grand Piano voice on channel 1 (this was the
specified format).
I put it on floppy and tried playing it on the Disklavier.  It played
but only using the Tone Generator, i.e. the piano sound came through
the speakers, but did not play on the actual piano strings.
How do I get this to play on the strings?
Thanks
Re: [disklavier] Playing imported midi files on disklavier
2006-10-09 by George F. Litterst
Good evening, everyone.
Chadbot, which model Disklavier do you have?
PianoBench
On Oct 8, 2006, at 4:39 PM, chadbot wrote:
> Help please:
> specified format).
> Thanks
Re: Playing imported midi files on disklavier
2006-10-09 by chadbot
The manual says "Mark II XG Series".  I don't have the actual model
number with me at the moment, it's the unit without the "record" feature.
(Which is why we're recording on a Roland digital piano and
transferring files via diskette)
--- In disklavier@yahoogroups.com, "George F. Litterst"
> Regards,
> PianoBench
> > Help please:
> > specified format).
> > Thanks
Re: [disklavier] Re: Playing imported midi files on disklavier
Good morning, everyone.
Chadbot, I don't have this model, but I suspect that the directions
would be the same as those for the full-featured Mark IIXG. Please
try the following:
--Press Function. Move the cursor to MIDI Setup and press Enter.
--In the MIDI Setup area, move the cursor to PianoPart and press Enter.
--Look for a setting called Import File. If necessary, press the
Right Arrow button to move to the next screen of this area.
If you are always going to use MIDI files with the piano part on
channel one, set L=1 and R=##. If you think that you might use MIDI
files in which the piano part is on other channels, set L=PRG(all)
and R=##. If you think that you will sometimes have files in which
the piano left- and right-hand parts are on separate tracks and you
want to be able to cancel the playback of just one track, set L=PRG
and R=PRG.
These defaults can be used to get you what you want most or all of
the time.
My instructions above enable you to set the Disklavier's default
setting for how to handle an Import File.
The simple explanation is this: When you record a song file using a
Disklavier or Clavinova, a special, Yamaha-specific message is added
to the file which tells Disklaviers and Clavinovas where to find the
left- and right-hand piano tracks. Any file that lacks this message
is considered to be an "Import File."
PianoBench
> feature.
> > Regards,
> > PianoBench
> > > Help please:
> was the
> > > specified format).
> played
> through
> > > Thanks
RE: [disklavier] Re: Playing imported midi files on disklavier
2006-10-15 by Director, Region 1
Hi George,
I had a chance to fix my problem today, thanks precisely to your comments
below.  It looks like someone else had been fiddling with the settings.  I
was able to fix it using your instructions.  Then I also did a "Factory
Reset" and the basic settings also provide what I need.
Thank you
Bruce
From: disklavier@...m [mailto:disklavier@yahoogroups.com] On
Behalf Of George F. Litterst
Sent: Monday, October 09, 2006 10:51 AM
To: disklavier@yahoogroups.com
Subject: Re: [disklavier] Re: Playing imported midi files on disklavier
try the following:
and R=PRG.
the time.
PianoBench
> feature.
> --- In disklavier@yahoogro <mailto:disklavier%40yahoogroups.com> ups.com,
> > Regards,
> > PianoBench
> > > Help please:
> was the
> > > specified format).
> played
> through
> > > Thanks
RE: Disklavier Mark 2 entire system for slae
2006-10-19 by Buddhika Wije
Hello to all.
I am about to dismantle a Yamaha DIsklavier DGH1B (5"6") in ivory, with a mark 2 disklavier. This I bought as a project as the piano sound borad and the keyboard was damaged.
The player part is It is in good condition and is working good working condition�except that�it does not go to record mode. Gives a error message saying sensor not connected when swithed on.
I hope to remove all the electronic parts from the piano and will list of ebay in the comming weeks and sell the piano sepratly as it�needs a lot of work.�I just wondered whether anyone would be intretested or have any suggestions.
I need to make way for a new piano that I hope to buy and the Yamaha has to go. I can send pictures if some one is interested.
Thanks
B�B
Express yourself instantly with MSN Messenger! MSN Messenger Download today it's FREE!
