Piano climate control systems for Disklaviers
2007-08-29 by Carol Beigel
This is my personal opinion about piano climate control systems.
Every situation is different, so your piano tech can advise you better than I
can.
Dampp Chaser makes an excellent piano climate control system.
Personally, I think every piano that is exposed to hot or humid
summers needs at least one dampp chaser rod and one humidistat. Grand
pianos need at least 2 rods installed underneath the soundboard. Never
have rods installed that are not controlled by the automatic humidistat.
This turns them on when the RH is around 42% and turnes them off when not
needed. They cycle on/off many times troughout each day! throughout all
the seasons.
I do NOT recommend the humidifier tanks for grand pianos unless they are
located in high rise apartment buildings or are surrounded by baseboard
heaters. Also NEVER put a humidifier tank in a Disklavier as I don't
believe in mixing water and electricity. The exception is an upright
disklavier where the entire climate control system can be mounted on the
back.
Most piano technicians would not agree with me about not using humidifier
tanks. My reasoning is that the pads in the tanks continually need
replacement for the system to work properly, and frankly, after 5 years this is
usually neglected. Also mold forms in the tubes and I really never thought
they worked all that well for what they cost. Better to have a humidifier
installed on your home heating system and have it serviced every year.
I think these climate control systems work great, protect your piano from
moisture swings, and are a good value. It is more important to protect
your piano from high humidity because the soundboard can swell up within a few
days and you can see the pressure ridges. This is when the damage is done,
but you don't see it until the soundboard shrinks during the heating season and
those pressure ridges become cracks. Some pressure ridges are normal -
especially if you really need to look hard to see them! If your piano
pitch is over A442 Hz and it was tuned regularly to A440, then consider
installing the dehumidifers under the board. Your piano tech can do
this.
Over the years I have had many customers argue that their grandmother's
piano never needed these things and it still plays. Fine. After 20 years,
these instruments often look they are 40 years old; the strings are rusty and
the piano action is stiff from taking on all the humidity over the years.
There is a mold or whatever it is, called vertigris that grows in the felt
action centers. It eats the cloth and does not really go away even when
treated. Some feel this is a reaction caused by the dye in the clother
reacting to a parafin treatment at the factory. Either way it can be
prevented by not letting your piano sit in high humidity.
If you think the gray market issue is argumentative, the climate control
issue is just as bad. All I know is that humidid areas give you peat bogs
and rot, and dry areas give you mummies! For myself, my piano is protected
again changes in humidity!
I usually try not to engage in shameless self promotion, but to save
bandwidth, I do have complete explanations and pictures of climate control
systems, baffles, disks, how a piano is tuned, piano first aid, and my comments
about choosing a new or used piano/disklavier and gray market pianos on my
website at: www.carolrpt.com
Carol Beigel
----- Original Message -----From: wandamusic@...Sent: Wednesday, August 29, 2007 10:25 AMSubject: [disklavier] Re: gray market pianos... and question about moisture control>>snipyou are trying to get to the truth. Thanks for looking after us!Can you recommend anything that will actually balance things out inside the piano? Telling me to climate control my condo is impossible - I simply cannot afford the high bills, which would be several hundrerd dollars more a month than I now pay.I did tell the sales person this before buying and I was told that Yamaha pianos are built ;so well that they will withstand these changes as long as they are not placed in an area that actually gets damp.Thanks in advance for any help, and thanks for your ongoing support to this list!Blessings,
Wanda
