DS6MK4PRO on the way
2008-10-02 by prsmith777
Hi everyone
Ive been lurking here for around a month in preparation for buying my
first Disklavier and I thank everyone for their contributions to this
wonderful group.  I recently was fortunate to have found a
spectacular DS6MK4PRO for a bargain and she is on her way to my home
in Louisiana.
The piano is coming from California where it was meticulously
maintained in a 45% humidity environment.  My livingroom hygrometer
has been reading 55-65% humidity the last month exect when Ike and
Gustav bumped it to 75%.  When I mentioned using a Dampp Chaser to my
piano tech, this was her response:
     "We do not recommend installing DamppChaser units on Disklavier
Grands, there are complications with the Disklavier unit power supply
that affect the performance. We do recommend controlling the humidity
in the music room instead. You can purchase a room unit from your
local HVAC contractor."
When I did a search of this topic, there were differing opinions.
Also, if I remember correctly, I believe in my phone conversation
with Bill Brandom last month he said there was no problem as long as
the humidifier part of the system with water was not used.
By the way, the room I am putting this piano in is 20 x 40 ft. I dont
want to have to put an ugly dehumidifier unit in there if I dont have
to.
Anyone care to comment?
Re: [disklavier] DS6MK4PRO on the way
2008-10-02 by Arthur J. O'Leary
Paul,
For what it\u2019s worth, I have had a Dampp-Chaser on my Disklavier for over 3 years and have not had a single problem with it or the piano.
Art
Reply-To: <disklavier@yahoogroups.com>
Date: Thu, 02 Oct 2008 11:25:01 -0000
Subject: [disklavier] DS6MK4PRO on the way
Hi everyone
in Louisiana.
to.
2008-10-02 by athomik
The Mark 4 has a lot more electronics hidden underneath than previous models, so you need to do be more careful where you site any water related parts. You need to make sure that any possible leaks are nowhere near any electrical parts unless you want to hear your piano go bang at some unexpected moment.
athomik
On Oct 2 2008, Arthur J. O'Leary wrote:
>Paul,
>For what it¹s worth, I have had a Dampp-Chaser on my Disklavier for over 3
>Art
>From: prsmith777
>Reply-To:
>To:
>Hi everyone
>in Louisiana.
>to.
>Paul
Re: DS6MK4PRO on the way
2008-10-02 by rwberry99
For what it's worth, I've had a Dampp-Chaser on my DC3A Mark III for
four years now.  I did not have the humidifier part installed, instead
I opted for a whole-house humidifier on my furnace.  This was a great
overall investment - I don't need to keep the thermostat set as high
in the winter (since humid air "feels" warmer) and I don't have the
dry skin and sinus problems that I had in the wintertime before
installing the humidifier.
My humidity problem is that in Missouri it's often too warm for the
furnace and too cool for the AC to run often enough to keep the
humidity down.  Today the high is expected to be in the mid-60's and
the humidity is over 80%.  There was a period where I had the AC set
to 58 degrees to keep the humidity in check - causing much pain on my
electric bill.
I also have a whole-house fan installed in my house, and I could only
use it 10-15 days of the year.  (Another investment I wholly recommend!!)
I had the Dampp-Chaser installed and just don't worry about it any
more.  I do have a humidistat sitting near the sound board of the
piano and the Dampp-Chased does it's job extremely well.
Of course, your mileage may vary.
-B
related
> unexpected moment.
> athomik
> >Paul,
over 3
> >Art
Re: [disklavier] Re: DS6MK4PRO on the way
2008-10-02 by Spencer_Lists
Greetings rwberry99,
The drying part of the Damp Chase system is just a heater. Difficult
to imagine that it would cause any problems with the electronics if
installed properly. Make sure that whoever installs it knows to not
stick it someplace stupid where it could cause problems.
Another possibility is to provide local heating near the piano with
some other creative out of the piano system. I am considering doing
this to my piano because I leave for months during the winter and
leave the heat in the house at just above freezing. This allows it to
get very damp at the piano. I am thinking of putting a liquid filled
baseboard heater of a good quality (not the cheap walmart type under
the piano to create a cloud of warmth near the piano. I could tent the
piano but think that is risky.
Any ideas on this would be appreciated. I hope to have a solution for
this winter as last caused a lot of damage to the piano regulation
although that was due to an extended power outage. If nothing else,
I'll use a damp chaser to protect the piano action as that is what was
messed up the most. A complete regulation is not cheap and is best
avoided.
> electric bill.
> -B
> related
>> unexpected moment.
>> athomik
>> >Paul,
> over 3
>> >Art
Best regards,
Spencer_Lists Chase        mailto:lists@...
67550 Bell Springs Rd.
Garberville,  CA 95542    Postal service only.
Laytonville, CA 95454    UPS only.
Lists@spencerserolls(dot)com
http://www(dot)spencerserolls.com
replace (dot) with a .
(707) 984-8356
2008-10-03 by Carol Beigel
Absolutely, because it is Louisiana, have the dehumidifier bars and
humidistat installed underneath the piano.  It will probably take 2 or 3
smaller rods placed around the electronics to protect the soundboard.
Also, the tech was correct, if the humidity was 75%, that you may also need
additional room dehumidification.  The idea is to maintain a CONSTANT
moisture content as close to 55%RH as possible.  You need both a Dampp
Chaser and a room machine.
Carol Beigel
Diskalvier tech
Sent: Thursday, October 02, 2008 7:25 AM
> Hi everyone
> in Louisiana.
> to.
> Paul
> To Post a message to the group, send it to:   disklavier@...
> To Post a private message to Todd Muncy, the group's founder and
> moderator, send it to:
> disklavier-owner@...
> To reach our group's web site go to:
> http://Yahoogroups.com/group/disklavier
> THINKING OF LEAVING THE GROUP?
> If you are thinking of unsubcribing because you are getting too much mail,
> go the the web site and change your email delivery option instead.  That
> will fix the problem, while maintaining your access to the group.  If you
> insist on leaving us completely send a blank email to:
> disklavier-unsubscribe@...
> Know someone who wants to join?  Have them send a blank email to:
> disklavier-subscribe@... or give them this link:
> http://Yahoogroups.com/group/disklavier/join
> Internal Virus Database is out of date.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.7.3/1694 - Release Date: 9/26/2008
> 6:55 PM
