Optimum MIDI settings on old Mark II (MX100II) used with computer software
2008-12-29 by boyler1999
Hello,
I am using the Metro SE MIDI sequencer and player on my Mac to bypass
the dead floppy drive on my old Mark II (MX100II) Disklavier.  So far,
it's been working great.  I read some of Carol's great web pages on
proper MIDI settings for the Disklavier, but I wasn't able to locate
the piano manual so I can't really figure out what all the MIDI
settings are used for, or which settings are optimal for my setup.  I
tried looking through the user manuals on the Yamaha web archive, but
it looks like they only go back to the Mark IIXG.  So, I figured I
would post the settings that my Disklavier is currently configured
for, and see if anyone has any comments.  (These settings are viewed
from the FUNCTION button.)
Since my setup seems to be working well, I don't think anything is
wrong, but just in case something looks glaringly wrong, I'd love any
feedback you experts might have.  Or, if you're so inclined to provide
commentary on what some of the important settings control, I'd be
interested.  For example, I have no idea what "Remote" is used for...
MIDI IN
            MIDI IN CH=01
            MIDI IN=REALTIME
MIDI OUT
            MIDI OUT=KBD OUT
            OUT CH=1
            SPLIT[OFF]
            TRANS= 00
            VOICE=###
            VOL=###
REMOTE
            REMOTE OUT=ON
            REMOTE IN=ON
ENSEMBLE
            PIANO PART MIDI OUT=ON
            RHYTHM CH=10
Bill
Re: [disklavier] Optimum MIDI settings on old Mark II (MX100II) used with computer software
2008-12-30 by George F. Litterst
Good evening, everyone.
Answers below:
On Dec 29, 2008, at 2:04 PM, boyler1999 wrote:
> Hello,
You can find many Disklavier manuals here:
http://www.yamaha.co.jp/manual/english/result.php
I am not sure why yours is not included. Most of the features are the
same as those in the Mark IIXG.
You might want to call Yamaha Piano Service: (800) 854-1569 between
8:30-5:00 PST and see if they can provide you with a manual or--better
yet--the Disklavier II Reference Guide (a spiral bound guide, printed
in color, that I wrote for Yamaha years ago).
> I
I recommend that you look at the MIDI section of the Mark IIXG manual.
> MIDI IN
> MIDI IN CH=01
So far, so good. This means that in your computer music software
program, you need to make sure that your piano track(s) are assigned
to MIDI channel 1 and that the non-piano tracks are assigned to
channels 2-16. If you have to change the track numbers, make sure that
you don't put different instruments on the same channel, and don't put
anything on channel 10 unless it was already assigned to channel 10.
Most of the files that you are likely to use are General MIDI files in
which channel 10 is reserved for the drum kit.
> MIDI IN=REALTIME
Real Time input does not give the best results. There can be problems
with rapid notes and repeated notes, especially. Best to use the Delay
In (500ms delay) setting. That way, the Disklavier buffers in the
incoming MIDI data and has time to figure out when to move each key so
that the hammers strike at the right time with the right intensity.
> MIDI OUT
> MIDI OUT=KBD OUT
This setting is correct if you wish to play the piano and record
yourself in the computer. However, if you wish to play an ensemble
song file on your computer (in which there is a piano part plus
orchestrated tracks), you need to set MIDI OUT = DELAY OUT. When you
do so, the MIDI Out port becomes a MIDI Thru port that passes the
other channels of MIDI data to the external tone generator and adds
the correct amount of delay to match that of the piano.
> OUT CH=1
> SPLIT[OFF]
> TRANS= 00
> VOICE=###
> VOL=###
These settings are fine when you are recording yourself into the
computer.
> REMOTE
> REMOTE OUT=ON
> REMOTE IN=ON
If these functions are on, you can control Start, Continue, and Stop
commands in your computer from the buttons on your Disklavier and vice
versa. In your case, I don't think you need these features, and I
suggest turning them off to avoid confusion.
> ENSEMBLE
This only affects what happens when you play a disk in your Disklavier
and want to send the data out to the computer. In your case, this
setting does not matter.
> RHYTHM CH=10
This is correct. It makes sure that percussion tracks are not
transposed when you use the transpose feature during playback. Since
you are not using the internal drive, this setting does not matter.
PianoBench
www.georgelitterst.com
www.timewarptech.com
Re[2]: [disklavier] Optimum MIDI settings on old Mark II (MX100II) used with computer software
2008-12-30 by Spencer_Lists
Greetings George,
some MIDI files can have their channel assignments redone
automatically to play on the DKV without having to move things around
in a sequencer using my MIDImod2 program. these are on the following
page (a fair distance down the page) also if needed there is a type1
to type 0 converter program. the page, :
http://www.spencerserolls.com/Files4Download.html
> Answers below:
>> Hello,
>> I
>> MIDI IN
>> MIDI IN CH=01
>> MIDI IN=REALTIME
>> MIDI OUT
>> MIDI OUT=KBD OUT
>> OUT CH=1
>> SPLIT[OFF]
>> TRANS= 00
>> VOICE=###
>> VOL=###
> computer.
>> REMOTE
>> REMOTE OUT=ON
>> REMOTE IN=ON
>> ENSEMBLE
>> RHYTHM CH=10
> Regards,
> PianoBench
Best regards,
Spencer_Lists Chase        mailto:lists@spencerserolls.com
67550 Bell Springs Rd.
Garberville,  CA 95542    Postal service only.
Laytonville, CA 95454    UPS only.
Lists@spencerserolls(dot)com
http://www(dot)spencerserolls.com
replace (dot) with a .
(707) 984-8356
