DOC to midi
DOC to midi
2009-01-16 by ISKI1@aol.com
Does anyone know how to convert DOC files to standard midi so they will  play
on VanBassco?
They play on YamPlayer with the DOC map but Yamplayer does not convert them
to midi correctly.
**************Inauguration '09:  Get complete coverage from the nation's
capital. (http://news.aol.com/main/politics/inauguration?ncid=emlcntusnews00000003)
Re: [disklavier] DOC to midi
2009-01-16 by athomik
The DOC disks should be in E-SEQ format so the utilities on Carol Beigel's site might work ( http://www.carolrpt.com/miditools.htm )
athomik
>on VanBassco?
>to midi correctly.
The file extension is .evt and .dir
They are not .fil (E-SEQ) files.
2009-01-16 by Carol Beigel
What is a DOC file?  Have you checked the Giebler website to see if he
has a utility to convert it to MIDI?
Carol Beigel
> will play on VanBassco?
> convert them to midi correctly.
> Inauguration '09: Get complete coverage from the nation's capital.
Re: DOC to midi
2009-01-17 by david962548
Hi
Yamplayer will only convert DOC to Midi it will NOT re-map the
voices as you have found out.  It does indeed convert them correctly
Eseq to Midi but it does not know they are DOC so does not apply any
voice mapping.
As you have them as midi files you can re-voice them manualy using
the data in the doc.map.
How many DOC disks do you want converted? I have some already done.
Dave
will  play
> on VanBassco?
convert them
> to midi correctly.
nation's
Re: DOC to midi
Hi
Email me direct for more infor on Yamplayer.
--- In disklavier@yahoogroups.com, "david962548" <magic_midi@...>
wrote:
> Hi
correctly
any
> voice mapping.
> Dave
they
> will  play
> > on VanBassco?
> convert them
> > to midi correctly.
> nation's
Re: [disklavier] Re: DOC to midi
2009-01-17 by Spencer_Lists
Greetings david962548,
i wrote a simple patch converter program that will change the patch
numbers in all occurrences in any midi files in batch mode. you just
give it a list of the old to new patch numbers. if anyone is
interested, i'll post it on my web site.
Saturday, January 17, 2009, 2:31:58 AM, you wrote:
> Hi
> voice mapping.
> Dave
> will play
>> on VanBassco?
> convert them
>> to midi correctly.
> nation's
Best regards,
Spencer_Lists Chase        mailto:lists@...
67550 Bell Springs Rd.
Garberville,  CA 95542    Postal service only.
Laytonville, CA 95454    UPS only.
Lists@spencerserolls(dot)com
http://www(dot)spencerserolls.com
replace (dot) with a .
(707) 984-8356
2009-01-17 by George F. Litterst
Good afternoon, everyone.
Spencer, will your program also get rid of DOC reset SysEx and replace
it with a GM SysEx? I think that this will be important.
PianoBench
www.georgelitterst.com
www.timewarptech.com
> > Hi
> > voice mapping.
> > Dave
> > will play
> >> on VanBassco?
> > convert them
> >> to midi correctly.
> > nation's
> Best regards,
> (707) 984-8356
Re: DOC to midi
2009-01-20 by david962548
Hi
There is no need to remove the DOC re-map SysEx if you intend to
play the file back on the PC only if you send it to a Yamaha device.
Midi
--- In disklavier@yahoogroups.com, "George F. Litterst"
replace
> Regards,
> PianoBench
patch
just
> > > Hi
correctly
apply any
> > > voice mapping.
using
done.
> > > Dave
they
> > > will play
> > >> on VanBassco?
> > > convert them
> > >> to midi correctly.
> > > nation's
> > Best regards,
> > (707) 984-8356
