Re: [elektron] SPS1 Ultra Wave Details
2005-04-19 by brainwashing
Well... i don't know the price for this but i can do the same things with Live and a Machinedrum... Only 20 sec of recording time ? Welcome back to 80's ^_^ I expect more from Elektron Brain
> Spoke to Daniel Elektron at the Sounds-Expo. > > The Ultra Wave is available as a hardware upgrade for the MachineDrum as > well as > being sold as new Unit/product. You will have to send your MachineDrum to > Elektron > though. He didn't say how much the upgrade would cost, but i'm sure it > will a lot less than > a new unit. > > Here is the low down! > > Exactly the same as the MachineDrum but with 2 new machines. > Rom Record and Rom Play. > Boots up same as the MachineDrum then has extra Rom loading screen. > Up to 32 Samples can be stored. > You can have 16 Rom Play machines at once each playing any one of your 32 > loaded > samples. > Sample time is approx 20 secs. Which I understand can be increased if you > choose a > different sample rate. > > The Rom Machine controls are (from memory). > Pitch, > Retrig, > RTime, > Rate, (sample resolution. Just on the record machine, i think) > Hold (ie Decay), > Start and End (To play sample in reverse put start to '127' and end to > '0'. Some interesting > LFO modulation possibilties here!). > There is no "real-time" time-stretch function. > > You can record on the fly, while other Machines are playing. > You set record in and out points as you would trig points. > For example If you are recording a live from a sound source the Record > Machine will keep > recording from the until you are happy. Then I presume it switches to a > play machine > when you have finished recording. An Elektron Demo guy was doing this with > a loop from > a record deck and it appeared to happen seemlessly. > > Daniel mentioned something about offereing a fast USB Midi adaptor to > speed up sample > transfers times when you buy the machine. Import via midi for a 4 bar loop > did seemed > painfully slow. > > Oh and I almost forgot. It sounded great. > > David > > > > > > > > Yahoo! Groups Links > > > > > > > >
