uw
2005-05-16 by analogback
Index last updated: 2026-04-28 23:22 UTC
do i understand correctly that the UW flash rom will hold the samples after power down? or do you have to reload/resample every time you turn it on? confused.
2005-05-16 by Corey Appleby
The ROM will hold the samples even after turning it off. It also has a bit of RAM to do on-the-fly sampling (sorta like the Kaoss Pad's two sample buttons) which will be lost after powering off. Or at least I think that's how it works. c.
On May 16, 2005, at 7:47 PM, analogback wrote: > do i understand correctly that the UW flash rom will hold the samples > after power down? or do you have to reload/resample every time you > turn it on? confused. > > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > In low income neighborhoods, 84% do not own computers. > At Network for Good, help bridge the Digital Divide! > http://us.click.yahoo.com/c9hWNA/3MnJAA/n1hLAA/XkLolB/TM > -------------------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > > > > >
2005-05-17 by analogback
--- In elektron-users@yahoogroups.com, "analogback" <gehayman@h...> wrote: > do i understand correctly that the UW flash rom will hold the samples > after power down? or do you have to reload/resample every time you > turn it on? confused. question for daniel, can you import wave files with bit rates other than 12bit or should these samples be resampled (soundforge dosent support 12bit)
2005-05-17 by niall munnelly
On Tue, May 17, 2005 at 02:06:26AM -0000, analogback wrote: > > question for daniel, can you import wave files with bit rates other > than 12bit or should these samples be resampled (soundforge dosent > support 12bit) in the video on sonicstate.com, owland referred to 16bit/44khz audio. the samples are probably companded. -- yours, niall. .. . . . . . . . . . aleph null. a simple insinuation around silence. http://syncretism.net .. .. gpg public key - http://www.aleph-null.net/niall.gpg .. ..
--- In elektron-users@yahoogroups.com, niall munnelly <aleph@a...>
other
dosent
> > support 12bit)
> yours,
> niall.
around silence.
thats cool.. thx niall
cant find that video tho?
> .. .. gpg public key - http://www.aleph-null.net/niall.gpg .. ..2005-05-17 by niall munnelly
On Tue, May 17, 2005 at 03:28:42AM -0000, analogback wrote: > > thats cool.. thx niall > cant find that video tho? http://www.sonicstate.com/news/shownews.cfm?newsid=2129 -- yours, niall. .. . . . . . . . . . aleph null. a simple insinuation around silence. http://syncretism.net .. .. gpg public key - http://www.aleph-null.net/niall.gpg .. ..
--- In elektron-users@yahoogroups.com, "analogback" <gehayman@h...> wrote: > --- In elektron-users@yahoogroups.com, niall munnelly <aleph@a...> > wrote: > > On Tue, May 17, 2005 at 02:06:26AM -0000, analogback wrote: > > > > > > question for daniel, can you import wave files with bit rates > other > > > than 12bit or should these samples be resampled (soundforge > dosent > > > support 12bit) > > > > in the video on sonicstate.com, owland referred to > > 16bit/44khz audio. the samples are probably companded. > > > > -- > > yours, > > niall. duh.. found it! regards, analogback
> > .. . . . . . . . . > . > > aleph null. a simple insinuation > around silence. > > http://syncretism.net > > thats cool.. thx niall > cant find that video tho? > > .. .. gpg public key - http://www.aleph-null.net/niall.gpg .. ..
