Swing without using swing on the MD?
2006-09-18 by Janne G:son Berg
Anyone else that is doing this? To get different swing feel per track and per note I am using the LFOs and parameter locks. Put the LFO on trig mode. Volume as destination, use the inverted square or the inverted ramps as waveform. Maximum modulation depth. Tweak the LFO speed to get the right swing feel. It is not the perfect swing alternative, but can be really useful. A disadvantage though is that you cut off the start of the sound, which usually results in a less defined attack for the sound. So, who else is doing this? Can be used on the Monomachine too. /Janne
