Two MD-UW bugs with the current OS
2006-09-27 by Robert
Looking for someone to test and verify these with me: Song Mode When controlling start/stop with external gear (the Monomachine in my case) Song mode does not reset to the first pattern of the song unless you; cursor to the top of the song on the MD, select it with Enter, press stop, play, then stop. Otherwise it will start from the exact position it was stopped on. RAM Machines Here's the scenario: Using RAM R1 and R2 to record the inputs, everything works great. Tweak the P1 or P2 machines to play backwards, and you lose the sample completely. Then you have to set your start and end back to default to get it before it will sound again. However, if you cut and paste the sample into a ROM slot, all is well and it can be mangled without a problem. Thanks all, -Robert
