Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
TM-1 article in Sonicstate
2006-10-07 by Tarekith
Here's a scoop…We've just heard from Elektron about TurboMIDI - the
evolution of MIDI…
While MIDI is the universally accepted standard, TurboMIDI is a
compatible evolution made possible from improved modern hardware.
TurboMIDI improves the bandwidth between two MIDI devices up to 10x
the original MIDI timing. The TM-1 USB MID interface that they have
just released does the job between a computer and a TurboMIDI
compatible device.
For example, say Elektron, at 10x speed, the MIDI clock can be 10x
tighter and 10x more note data can be passed though at one particular
time. All MIDI timing becomes more accurate. This is especially valid
for Mac OSX users.
Increasing the bandwidth also makes sample transfers (or OS upgrades)
a much more delightful experience.
The TM-1 is fully MIDI compatible, so it works together with any MIDI
gear out there.
You can use any sequencer or other application together with the TM-1.
To engage TurboMIDI-mode, you just press the button.
Elektron told Sonicstate that instead of releasing new versions of
their Machines with USB ports, the TM-1 now virtually transforms your
MIDI ports into USB. Anyone who wants this improvement can now do so
by going TurboMIDI without the usual need of selling and buying new.
Some key facts:
    * Up to 10x TurboMIDI Speed
    * USB 1.1 and 2.0 compatible MIDI interface
    * Full standard MIDI Support
    * Sleek Brushed aluminium bent casing with steel insert
    * 1xMIDI IN, 1x MIDI OUT
    * USB Powered
    * WINXP & MAC OSX driver free (USB audio standard compliant)
    * Glossy User's Guide (Elektron Style) included
TurboMIDI is an open standard, free for anyone to implement.
Tarekith
http://www.tarekith.com
