Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
[MnM] Triggering patterns from a DAW?
2004-01-23 by puretokyo2002
Trying to get my head around the Midi Implementation part of the manual...
Say I want to play Pattern B08, how would I trigger it from a computer sequencer (I
use DP4)? And if I want to change to, say, Pattern B10 on the fly?
How do I do the same on my MD as well?
All help appreciated :)
Angus.
Re: [MnM] Triggering patterns from a DAW?
2004-01-25 by endlessnessisticman
I'm surprised nobody answered this yet...
Anyway there is a menu in the Global menu.  This is MD. I dont have
mnm but I assume it's similar.  I believe it's the midi menu.  There
is a pattern key map.  Look for the Map part of the Midi menu.  It
should show the pattern and a key.  You can change the key and press
enter.  I don't know more than this because I've never used it.  I
think there is more in the manual.
--- In elektron-users@yahoogroups.com, "puretokyo2002"
manual...
> Angus.
Re: [elektron] Re: [MnM] Triggering patterns from a DAW?
2004-01-25 by jmelnyk@cs.kent.edu
the MnM equivalent is: "global->control->multimap edit" and then set the
note you wish to use to trigger a specific pattern (offsets and lengths of
the pattern playback are also programmable in this menu).
also, you need to use: "global->control->midi chanls->multi map ch" to set
the MIDI channel you wish to use to trig the patterns using the notes.
hope that helps!
Joe
