Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
[FEATURE REQUESTS] => More info on kit list / Safe kit save-erase / More info on global setting
2004-02-02 by onosendai
What a pitty ! It's a very good idea
I understand that you don't want the MD to become to complicated, but it's
very important to us to have the best sound we can have. And add this kind
of parameter in the global setting it's the best choice : user can choose
the one they want, and everybody is happy
Like with the new EQ in Reason 2.5, they make a switch behind the mixer and
there isn't any problem (and the sound is better)
New there is my [FEATURE REQUEST]
- MORE INFO ON KIT LIST :
An important information is missing : at what pattern a kit is assigned !
Now if i want to erase some kit (for exemple when there is no more free
slot) i have to test ALL the pattern to check that i don't make a big
mistake, boring !
=> It would be nice to press "function" on a kit (in the kit list) to show a
window with the name of all the pattern whitch use this kit
- SAFE KIT SAVE/ERASE
Add this kind of message when erase or save on an existing kit : "Warning !
This kit is used by another pattern, are you sure you want to do this ?" (i
have messed a lot of pattern because of that)
- MORE INFO ON GLOBAL SETTING
Add the possibility to name the slot of the global setting and when pressing
"function" a window show (just show) a list of all the choice of this
setting (more fast to check the global setting i need, because after 3 month
of using i can forget the setting i make)
Daniel, i count on you ;)
Ono
To: <elektron-users@yahoogroups.com>
Sent: Sunday, February 01, 2004 10:29 PM
Subject: [elektron] Re: [MD FEATURE REQUESTS AND BUGS LIST]
> --- In elektron-users@yahoogroups.com, not known <spectralab1@y...>
> wrote:
> > just out of curiosity, would it be possible to
> > implement a setting on the global level that would
> > allow users to switch between the new and "classic"
> > settings, so that each user can decide for themselves
> > which is preferable (or, conversely, switch between
> > two entirely different versions of their saved kits)?
> > just curious... I thought I'd offer the idea as a
> > possible workaround to the problem you mention above.
> Probably technically possible, but I would prefer not doing this.
> Daniel
> To visit your group on the web, go to:
>  http://groups.yahoo.com/group/elektron-users/
> To unsubscribe from this group, send an email to:
>  elektron-users-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
