Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
MD: Changing kits from Cubase SL 2?
2004-10-15 by mackroscopic
I'm trying to sequence my MD with Cubase SL 2.
My MD is set to local off.
I can change sequences but not kits.
Is there a way to change kits?
If I can't change kits, how do I assign a kit to a blank sequence?
Re: [elektron] MD: Changing kits from Cubase SL 2?
2004-10-15 by Joseph Melnyk
sysex messages are the only way, I believe.  the back of the manual has
details on
how to do it.
2004-10-15 by niall munnelly
if you're using os 1.12, then use program change messages.  if you're using os 1.19,
then you're out of luck, unless you...
select a blank sequence and load a kit.  it'll stick.
yours,
niall.
aleph null.                             a simple insinuation around silence.
http://syncretism.net
.. .. gpg public key - http://www.aleph-null.net/niall.gpg .. ..
