Apple CD150
2003-02-14 by Josue R. Santana C.
Dear All: Recently I bouthg an Apple CD150 in excellents conditions. I conected it via SCSI to my EMAX II but it does not recognize it. My EMAX has an internal Hard Disk QUANTUM that I think it is not the problem because when the EMAX did not have it yet, it did not recognize it either then. I did used the ID from the 2 to the 7. When I try to access the CD150 with an ID from 2 to 7, the EMAX gets freeze. I\ufffdm sure that the CD150 is working ok. because I tested it in a Power Mac 8100. The "terminator" that it has is "passive" type and I think it might be an "active" type so it could work good. I haven\ufffdt found information related to the "terminator" type that I must connect to the CD150. Beside, the SCSI EMAX system is ok, because it recognize well an IOMEGA ZIP 250. Could it be that the internal Hard Disk and the SCSI input are both using the same Bus? I don\ufffdt know the EMAX electronic distribution. So I would really appreciate if somebody could please give me any orientation about this problem. Thanks. Josue
