Emax
formatting disks for Emax Plus Rev 1.0?
2014-09-30 by nickshopa@...
Hi everybody. So I’m new to this forum and to the Emax in general, so I’ve got some basic questions that I’m hoping you guys might be kind enough to answer for me. I just got an Emax Plus Rev 1.0 HD with the SE upgrade. It's got a slim floppy compact flash SCSI drive installed. It can also take the traditional 3.5" floppies.
My first question is regarding formatting disks. I obtained an OS disk (3.5") with operating system 3.2, but the software version on my Emax is Plus Rev 1.0. Does this mean I’ll need to track down a floppy disk with the Plus Rev 1.0 software on it in order to format other floppy disks? If I copy the OS 3.2 to the Emax it will erase and write over the (superior?) Plus Rev1.0 software with the older 3.2 software. Or maybe I’ve got it wrong- is the 3.2 OS better than the Plus Rev1.0?
2nd question should be simple, and I’m sure I’m overlooking something: Some of my presets only have 4 note polyphony. Why is this and how can I change this to 8?
Thanks for any advice.
Re: [emax] formatting disks for Emax Plus Rev 1.0?
2014-09-30 by Ted Summers
In regards the 3.2--- booting from 3.2 floppy won't even see the SCSI HD, etc. 3.2 is the older OS....
You shouldn't use 3.2 except as an emergency "boot up" disk to verify the Emax can boot up.
Optimally, you should have a couple of disks that have PLUS 1.0 for that purpose also.
If the Emax boots from HD / flash media and you are seeing version information in the menu as Emax PLUS 1.0, choose to format a floppy disk and it will write that OS to the disk you are formatting.
Then to verify the floppy is valid, power off and boot from it.
-Ted
On Tue, Sep 30, 2014 at 12:13 PM, nickshopa@... [emax] <emax@yahoogroups.com> wrote:
2014-10-01 by Nick Shopa
Thanks so much Ted, I'll give it a shot.
Nick
> On Sep 30, 2014, at 3:57 PM, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> wrote:
> -Ted
2014-10-02 by Nick Shopa
Hey Ted, I tried to format floppys after the Emax booted from its CF compact flash (SCM PCD50b) SCSI drive and at the end of the disk formatting process it reads "disk error." I've tried several times with several different disks. Any recommendations moving past this? Really, I don't even care about the compact flash drive, I just want to use floppys with it.
Anybody know of any good Emax repair shops in NYC?
> -Ted
2014-10-02 by Ted Summers
Are you using TRUE DSDD disks? People's successful use of HD disks is sketchy...YMMV. it is also possible the floppy drive is going bad if it wasn't new to begin with (ie person bought a used one off ebay to put in).
Replacement drives are out there - you can pick up a NEW slim floppy for as little as $15 on ebay....
-T
On Thu, Oct 2, 2014 at 3:57 PM, Nick Shopa nickshopa@... [emax] <emax@yahoogroups.com> wrote:
-Ted
On Tue, Sep 30, 2014 at 12:13 PM, nickshopa@... [emax] <emax@yahoogroups.com>; wrote:
2014-10-03 by Nicholas Shopa
I guess I'll swap out the floppy drive with a new one then! What particular brand of disks do you recommend? I'm using Maxell MF2HD and Sony 10MFD-2HDcf. I think Sony's labeling is a bit excessive...
Thanks
On Thu, Oct 2, 2014 at 7:10 PM, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> wrote:
-T
On Sep 30, 2014, at 3:57 PM, Ted Summers djtbs1@gmail.com [emax] <emax@yahoogroups.com> wrote:
-Ted
2014-10-03 by Ted Summers
any DSDD disks should work properly. You cannot use HD at all unless you cover the hole for the HD (high density). If you haven't been doing that, that would be the first problem...
-T
On Thu, Oct 2, 2014 at 6:00 PM, Nicholas Shopa nickshopa@... [emax] <emax@yahoogroups.com> wrote:
Thanks
-T
On Sep 30, 2014, at 3:57 PM, Ted Summers djtbs1@...m [emax] <emax@yahoogroups.com> wrote:
-Ted
Indeed that was that problem- and that fixed it! Taped over the hole- now disks are formatting perfectly.
Thanks so much!
On Thu, Oct 2, 2014 at 9:09 PM, Ted Summers djtbs1@... [emax] <emax@yahoogroups.com> wrote:
-T
On Thu, Oct 2, 2014 at 6:00 PM, Nicholas Shopa nickshopa@gmail.com [emax] <emax@yahoogroups.com> wrote:
Thanks
-T
-Ted
2014-10-06 by Garth Hjelte
Really try to get true DS/DD disks. Taping over the hole suppresses the software-based restrictions, but it never addresses (and never could) the core problem, which is that DS/HD floppies have a much lower magnetic property (coercivity) than DS/DD disks. So the data written is much less likely to "stick" initially or throughout time.
Getting DS/DD disks online is really easy, just google it.
I have a lot of experience with this - taping the hole is good in a pinch short-term but causes lots of problems long-term. It's not one of these mythical things, a DS/HD floppy hole-taped is basically a very poor quality DS/DD. Don't risk it, you don't have to.
Garth Hjelte
Sampler User
2014-10-06 by Nick Shopa
Thanks for the tip Garth, I'll get on that right away.
Nick
> On Oct 6, 2014, at 9:49 AM, Garth Hjelte garth@... [emax] <emax@yahoogroups.com> wrote:
> Garth Hjelte
> Sampler User
