Emax
Samples sound like tremolo/vibrato is constantly on
2015-03-18 by jeff norwood
Hello Emax group
 i recently purchased a drive and OS 3.2 Disk to get my EMAX SE back up and running. But now when I sample regardless of adjusting the input db volume, the sample plays back with a strange effect and I can't figure outwhy? it sound like the tremolo/vibrato is on, when heard thru the headphones or L/R outputs. has anyone else experienced a similar problem or have any ideas?
Thanks in advance
Re: [emax] Samples sound like tremolo/vibrato is constantly on
2015-03-18 by emma
Keyboard or rack
Sent from Samsung Mobile
-------- Original message --------
From: "jeff norwood jaedoo3000@yahoo.com [emax]" <emax@yahoogroups.com>
Date: 18/03/2015 06:12 (GMT+00:00)
To: Emax <emax@yahoogroups.com>
Subject: [emax] Samples sound like tremolo/vibrato is constantly on
Hello Emax group
Thanks in advance
2015-03-18 by cadena100rb@...
May sound silly on my part, but check the Modulation wheel position. Mod Wheel zero position is a bit weird, and I it took me a while to figure out what was wrong with mine years ago. Same problem: everything sounding like vibrato on playback
2015-03-18 by J
Emax SE keyboard
Sent from my Sprint phone
"emma jammie.emma@blueyonder.co.uk [emax]" <emax@yahoogroups.com> wrote:
Keyboard or rack
Hello Emax group
Thanks in advance
2015-03-18 by emma
Go into diagnostics and check the mod wheel has not been set at the wrong position
You can reset it
If it persists then there is a problem ssm2300 ic as the sample and hold samples the voltages of the modwheel and pitch wheel and sends the digital information to the cpu via the abc I/0
From: "J jaedoo3000@yahoo.com [emax]" <emax@yahoogroups.com>
Date: 18/03/2015 17:46 (GMT+00:00)
To: emax@yahoogroups.com
Subject: Re: [emax] Samples sound like tremolo/vibrato is constantly on
Emax SE keyboard
Keyboard or rack
Hello Emax group
Thanks in advance
2015-03-19 by J
I cannot access the diagnostics nor do I have the option it appears. I have an emax SE but my screen says software Rev 3.2. Online the latest is for the Se/HD models appears to be 1.1. This may be the issue!?
You can reset it
Emax SE keyboard
Keyboard or rack
Hello Emax group
Thanks in advance
2015-03-19 by emma
Are you sure the os says 3.2
As when upgraded to se it usually gives error saying wrong type os
All emaxes still have diagnostic routines its in the software menu master menu it allows you to check memory floppy drives read and write it allows to check the triggering of keyboard to isolate voices if there is a bad voice check wheels and if you have scsi it allows you to format scsi disks
Are you sure yours is a se and not just a hd as these had special software and did not have se so could load 3.2 os
One way yo find out if its an se is to use the se upgrade disk
If its not been upgraded it will upgrade to se if it has it will just load the os
Date: 19/03/2015 09:10 (GMT+00:00)
You can reset it
Emax SE keyboard
Keyboard or rack
Hello Emax group
Thanks in advance
2015-03-19 by J
The front of my keyboard does say SE and spectrum interpolation digital systems. In the master menu , my menu only goes to 8 and my special function only goes 1-6 but no diagnostic option? I'm guessing its because my OS is 3.2 instead of 1.1?
You can reset it
Emax SE keyboard
Keyboard or rack
Hello Emax group
Thanks in advance
2015-03-20 by Ted Summers
OS 3.2 won't have the SE functions.
That technically isn't the right OS for your machine as you functions simply won't be available in the menus.
However, it will still boot the Emax (at least mine does).
Go into Special - then #4 Recalibrate.
You can calibrate everything and / or double check the calibrations of the items from in that menu.
If you haven't gotten the manuals, I would suggest to get them.
I believe the process for calibration is covered in one of them….
-T
On Mar 19, 2015, at 11:11 AM, "J jaedoo3000@... [emax]" <emax@yahoogroups.com> wrote:
From: "J jaedoo3000@... [emax]" <emax@yahoogroups.com>
You can reset it
Emax SE keyboard
"emma jammie.emma@....uk [emax]" <emax@yahoogroups.com> wrote:
Keyboard or rack
From: "jeff norwood jaedoo3000@... [emax]" <emax@yahoogroups.com>
Hello Emax group
Thanks in advance
2015-03-20 by J
I tried the recalibrate feature, but to no avail. Does anyone know where I can get the OS 1.1 for the emax se already on disk?
-T
On Mar 19, 2015, at 11:11 AM, "J jaedoo3000@yahoo.com [emax]" <emax@yahoogroups.com> wrote:
You can reset it
Emax SE keyboard
Keyboard or rack
Hello Emax group
Thanks in advance
