Emax
i need slider specs for emax 2
2015-07-17 by johnnygadgetband@...
i'm replacing the slider and i would like some specs to look for when finding a replacement. i don't care about the slider being able to fit where the original one is and i also don't mind if i have to use a knob instead. does anyone already know what kind of slider/knob will be compatible? thx for any help.
Re: [emax] i need slider specs for emax 2
2015-07-18 by Ted Summers
It’s a 10K slider (stereo, I believe - the service manual doesn’t say)
Dimensions: 2.375” (60mm) long x  .363” (9.33mm wide)
Slider throw length is  2.0475” (52mm)
2 contact points at one end, 1 contact point on the other end, and 4 points on the side for mounting / possibly grounding purposes.
Hope that helps.
-T
On Jul 17, 2015, at 3:49 PM, johnnygadgetband@... [emax] <emax@yahoogroups.com> wrote:
