Emax
Emax Midi not working
2015-08-27 by shawnjward@...
i have an Emax 1000 keyboard that has been rock solid but all of a sudden it doesn't send midi. it receives but freezes
i have ruled out bad midi cables and my midi interface
any tips?
Re: [emax] Emax Midi not working
2015-08-27 by Ted Summers
check the midi output with a midi test circuit:
or
and there’s also a midi test in the Emax Diagnostics PDF…
The same Serial UART does both the RS422 and the MIDI- you are supposed to only hook one cable at a time.
So if you have both cables hooked- unhook the one you aren’t using presently.
IF the midi test fails and you don’t have both RS422 and MIDI hooked, you could also run through the Serial test and see if that fails too.
If both were to fail, at that point you might be looking at the UART or the rest of the circuit in relation to that port...
-T
any tips?
RE: [emax] Emax Midi not working
2015-08-27 by Shawn Ward
thanks Ted
got it working now :)
To: emax@yahoogroups.com
Date: Wed, 26 Aug 2015 19:29:55 -0700
Subject: Re: [emax] Emax Midi not working
or
-T
On Aug 26, 2015, at 6:35 PM, shawnjward@... [emax] <emax@yahoogroups.com> wrote:
any tips?
