Emax
Emu emax 1 and Emulator 3
2016-04-03 by yusteromerooscar@...
Somebody knows if Emu emax 1 library could be compatible with Emulator 3?
I haven´t found info about this possible compatibility..
Thank you
Ang.:[emax] Emu emax 1 and Emulator 3
2016-04-03 by Brian Ronn
Emax 1 is not compatible with Emulator 3.
Best regards Brian
Sendt fra Yahoo Mail på Android
  Den søn., apr. 3, 2016 kl. 2:20 skrev yusteromerooscar@... [emax]<emax@yahoogroups.com>:
Thank you
Re: Ang.:[emax] Emu emax 1 and Emulator 3
2016-04-03 by Garth Hjelte
Really? So a Emulator 3 (plain) or 3X can read Emax II but not Emax I?
If not, you can always use Translator to convert the Banks/Presets to E3/E3X format. (I think EMXP does it too?)
Garth Hjelte
Sampler User
Re: [emax] Emu emax 1 and Emulator 3
2016-04-07 by Michael Wisbech
To my knowledge the Emax Library is a convertion of the emulator 2 library.
( Through I could be wrong..)
> I haven�t found info about this possible compatibility..
> Thank you
2016-04-09 by dfiorucci@...
To the best of my knowledge all of the recordings for the EII where originally done on a Sony PCM F1.
Those same recordings where used to create the Emax factory library.
So there was no direct transfer but the recording source was the same.
Re: Emu emax 1 and Emulator 3
2016-04-10 by andrei.kudryavtsev@...
I heard many that PCM F1 was used to sample original library. But do you have an idea how physically did they do that? Was there any special interface that EMU developed for EII at that time?
