Emax
Is this normal?
Is this normal?
2003-11-04 by bassmeter
My Emax 1 looses it's current memory when I format a floppy
disc.  Was just wondering if my machine has a bug, or if it
happens to everyone?  Also, is there any way around this
problem?  Thanks a lot,
Peter
RE: [emax] Is this normal?
2003-11-04 by Hermann Seib
Hi Peter,
> problem?
If you read what it says before it starts the formatting process, you
wouldn't ask... go on, READ the text you have to confirm with Yes before it
does anything... that's no bug, it's a necessity because of the small memory
size in the Emax. The only way around this problem is to keep a aset of
preformatted disks at hand, I guess (or use EMX on the PC, but I've found it
to be less reliable than disks formatted directly on the Emax).
Bye,
  Hermann
Re: Is this normal?
Thanks Herm,
Didn't want you to think I don't like to read or something.  When
you select format it says "erases memory".  This COULD mean
memory on the disk you are formatting, which made more sense
to me, since other samplers I own of the same age don't loose
internal memory when formatting a floppy.  Glad to know my
machine is operating well.
Thnks again,
Peter
--- In emax@yahoogroups.com, "Hermann Seib" <
shadowcast@e...> wrote:
> Hi Peter,
> > problem?
you
Yes before it
small memory
a aset of
but I've found it
> Bye,
>   Hermann
RE: [emax] Re: Is this normal?
Hi Peter,
> Thanks Herm,
Hmm, on second reading my remark came over in a slightly smartass
fashion... I apologize. It wasn't meant that way.
Bye,
  Hermann
Re: Is this normal?
Smart ass, no.  Ignorant, maybe.  Apology accepted.
-Peter
> Hi Peter,
> > Thanks Herm,
smartass
> Bye,
>   Hermann
RE: [emax] Alchemy 3 Sent !!!!!!
2003-11-14 by Andrew Lunch
I have done a mail out of alchemy.
If you didn't get a copy but want one just post your address.
I am in a good helpful mood so make the most of it
<http://www.smileycentral.com/?partner=ZSzeb001> Wakka Wakka
Andy
 <http://www.smileycentral.com/?partner=ZSzeb001> Moony
 <http://www.smileycentral.com/?partner=ZSzeb005>
I take it smiles don't work then
Andy
