Emax
Global Omni Mode ?
Global Omni Mode ?
2004-03-24 by phonophobie
Since 4 month i have my Emax now - i saved all my Presets with
Midisettings in Omnimode. The problem now is when ever i want to play
any other gear that is on the same midichain, the emax plays it´s
preset too. I know i can modify each preset and set it to "poly mode"
but thats much work to do... My Emax Presets are all on channel 11.
I am just wondering if there is a global setting for all presets to
work in poly mode.
I couldn´t find anything in the manual
-phono
Re: [emax] Global Omni Mode ?
2004-03-24 by John Silveria
What OS are you using?
What you want to change is Master : (9)Special : (2)MIDI Master on an Emax II. It
somewhere like that on the Emax as well. It will set the global channel on the Emax,
there is no reason to set the Preset PolyMode I'm not even sure why that was put in the
OS unless early versions didn't have a MIDI Master.
On 24 Mar 2004 at 13:23, phonophobie spoke unto me:
> Hi,
> work in poly mode.
> -phono
> http://www.silveriafamily.com
**************************John Silveria II****************************
                        MSN: emaxjs@...
------------------ http://www.silveriafamily.com ----------------------
Re: Global Omni Mode ?
I got it.. i am on emax(1) with SE OS. The setting is a function of
the se os at "master/special/2".... :)
thanks
-phono
an Emax II. It
that was put in the
> > Hi,
play
mode"
11.
to
> > work in poly mode.
> > -phono
> > Yahoo! Groups Links
>                         MSN: emaxjs@h...
