I would think the modulation wheels are moving potentiometers. If they
are, verify that the wheel isn't held on by a set screw. If it is the
screw may be loose, which would cause improper adjustment of the pot
and it could then stay at an incorrect location in its turning radius
(ie- turns, but when springs back, doesn't go back). When you modulate
up again, you might then break the pot. If that is the case, you should
be able to get a replacement fairly easily. Just find out how many
ohms it is and find out if it is a audio or linear taper... I have an
Emax 1 so unsure if that part would be the same or not. Rob at emu
archive might know what the values/ and taper are.....pots are pretty
standard. There are a few varieties, but not that many, and if you can
find the value, your good to go. You could get both styles of taper and
see which one seems to work "properly" so to speak. You can also
determine the value by hooking up a digital multimeter to the two
outside lugs and noting the measurement. many times the pot will
indicate value on the side. or bottom.....
Ted
On Nov 15, 2004, at 6:21 AM, Steve Adam wrote:
> Hi
> I have an Emax II keyboard which started playing up a while back in
> terms of making sound but still worked as a master keyboard so I've
> continued to use it as my main live keyboard for triggering sounds
> elsewhere.
> Recently the pitch and mod wheels have started playing up.
> Basically, after a short while they stop working and don't come back
> unless I switch off and let the machine completely cool down. I've
> tried re-seating the ribbon cable connector inside but it doesn't
> make much difference. It can temporarily restore them, but they go
> off again fairly soon.
> I suspect given the other problems that this is further signs of
> internal circuitry problems that can't easily be fixed and that I'm
> reluctantly going to have to consign it to the scrapheap. But if
> anyone has any ideas I'd love to hear them - I have a gig this
> weekend and my only other MIDI keyboard isn't velocity sensitive.
> Cheers
> Steve�
> http://www.silveriafamily.com
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <111004_1104_f_300250a.gif>
> <l.gif>
> � To visit your group on the web, go to:
> http://groups.yahoo.com/group/emax/
> � To unsubscribe from this group, send an email to:
> emax-unsubscribe@yahoogroups.com
> � Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
