Re: [emax] Re;External Zip Drive
2005-03-13 by Damir Kristijan Rogina
Hi I recently bought EMAX RACK .......1020...and I also had at home 20 MB hard disk, SCSI NCR IC and SCSI connector wich I took out of dead HD SE some time go.... I inserted SCSI NCR IC , connected HD and made HD OS and everything works fine BUT I also have external SCSI connector ????WHERE TO CONNECT IT INSIDE EMAK RACK?????????????????????????? I'm gonna to instal SE OS tonight ................ BTW is there new CD wich might work with EMAX SCSI if I make Emax cd rom ZIP........... Damir
To: emax@yahoogroups.com
Sent: Monday, March 14, 2005 6:41 AM
Subject: Re: [emax] Re;External Zip Drive
Easy, just follow the instructions at emulator archive about getting an internal scsi cable withtwo ends, and get and internal to external scsi adaptor, drill the hole in the back for the scsi connector and you're pretty much set.
You will need to do the SE upgrade (available in the files section) and install the Plus OS to select scsi id of the drive you are loading from (the internal HD is zero, the xip drive is selectable on the zip itself.
Sent: Sunday, March 13, 2005 11:21 PM
How would I do the upgrade with an emax HD? I saw one on ebay and I am considering buying it. Thanks for your help, Angelo
http://www.silveriafamily.com
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
http://groups.yahoo.com/group/emax/
emax-unsubscribe@yahoogroups.com
ADVERTISEMENT
Yahoo! Groups Links
__________ NOD32 1.1024 (20050311) Information __________
This message was checked by NOD32 Antivirus System.
http://www.nod32.com
