Emax
foot pedal calibration problems
2006-03-06 by Phil
Hi folks,
i recently bought myself a foot pedal,
plugged it in and found that the response was very limited -
most of the movement of the foot resulted in nothing, but the top end
shifted up an octave.
i looked through the archives of wisdom on the list here,
and found some posts on recalibrating foot switches,
so i tried recalibrating [master,9 recalibrate footpedal]
and seem to have accidentally set all values input to equal 255 output -
so now there is no response to the pedal..
is there a way to reset to a default calibration?
[I'm guessing i could locate the battery and unplug it to wipe all
memory & it would go back to factory settings?]
sorry about the lengthy post
phil
Re: [emax] foot pedal calibration problems
2006-03-06 by PBass58@...
I tried Yamaha or Roland volume pedals and neither work.  I found that an
Ensoniq pedal does work (or Moog...same pedal made in Italy)!  Try that, about
$30 -$40 at Musician's Fiend.  I have an old Arp footswitch for the sustain
pedal.  Should be simple on/off switch.  Good Luck!
