Emax
ticking power supply
2006-03-22 by synthmdl76
I have seached the post and seen simular probs.  The leds and displace
just flash but no power up.  The supply is just ticking and I think it
may be a overcurrent protection cuase a cap is bad.  All my output
voltages are messed up.  the +/-12 is at 8v and the 5 is at 3.5v.
anyone seen this problem and know for sure what it may be?  I may just
replace all the caps to see.
Re: [emax] ticking power supply
2006-03-22 by Russell Rose
hate to say it, but that is the suresign of a power supply gone
south, hope i am wrong.
that there are shorts( leaky bypass caps) across the 5 and 12 volt
rails all of a sudden
seems as likely as  maybe the cheshire cat playing croquet with the
Queen of Spades. and then winning.
> http://www.silveriafamily.com
2006-03-22 by ted Summers
Well, while Russ may be right, if you have the time, you could
certainly pull those caps and try them on a DMM and see if they are
shorted (although a capacitance tester would be a better bet, if you
had access to one). You have nothing to lose but the time spent
looking into it.... if a cap goes bad, it might take other
components  with it. If my supply was dead, I would try and fix it.
After removing the caps (especially if one was shorted), you could
then start measuring points on the PCB to see if anything else
appears shorted on the board. But that is just me....with 15+ years
of working on electronics in industry, even without a schematic I
could figure out what was wrong... then the question would be
availability of the old part.... that would be the hardest thing to
get potentially....
You could also look for cold solders. When I replaced my LCD and
floppy drive right after buying my Emax, I resoldered the complete
power board to try and avoid future failure that could be caused by
cold solders.....
Weigh that with how much expertise you have. You could get an open
frame PS that would do the job for about $30 if you know where to
look. Some people have used a PC power supply (small form factor). I
would have to look at my PS before I would commit to the PC way.....
Ted
>> displace
>> think it
>> just
>> Yahoo! Groups Links
ON FUrther thought, did you try disconnecting the power supply from
the load and then testing the power supply?
To be on the safe side, you may want to shunt the output of the
supply with appropiate load resistors before
you attempt this. say 15ohm for the 5 volt side and  25-40 ohms for
the 12 volters. By the way last time I checked
EPR Electronics had drop in replacement power supplies, kinda pricey.
> get potentially....
> cold solders.....
> Thanks,
> Ted
>>> displace
>>> think it
>>> just
Re: ticking power supply
2006-03-23 by synthmdl76
Well, It aint even ticking now.  and no voltage passed the large metal
transformer... I think its dead.  I have a real hard time believing we
cant get a simular newer supply on the net besides having to use a pc
supply.  Heck, its only 5, +\-12 volts ;-/  Im going to do some
looking... ill let you know... Thanks all for your input, you guys rule!
Well, The more I look the more I like the $20 pc power supply.  You
can get them with a quit fan and they provide PLENTY of current.  I
assume there are clean running if they are used in pc's.  This seems
Like a simple logical choice.
Well after reading the post from another lad on this page im confident
in the pc power supply upgrade...
Re: [emax] Re: ticking power supply
2006-03-23 by aprea
sure!
it's the way to go.
very easy too (thank you Jean-Marc!)
feel free to ask some advice.
regards,
davide
>Yahoo! Groups Links
Davide,
You have been using this setup for what, 5 months and no problems?
You know how long Jean-Marc has been using it?
--Mike
--- In emax@yahoogroups.com, davide:aprea <pasquale.aprea@...> wrote:
> sure!
> it's the way to go.
> regards,
> davide
> >Yahoo! Groups Links
2006-03-23 by aprea
5 months and no problems of any sort
about jm's experience i don't know, but sure he knows.
anyway, as far as i know,  pc psu should be more reliable than the
original and the output cleaner, more gentle towards emax components
best-regards
davide
synthmdl76 wrote:
>Davide,
>--Mike
>>sure!
>>it's the way to go.
>>regards,
>>davide
>>>Yahoo! Groups Links
>Yahoo! Groups Links
2006-03-25 by synthmdl76
I added some pic of my PSU upgrade... and a upgrade it is.  The fan is
really quite(cant hear it over my other gear) and the circulating air
in the Emax is a Plus to.
I added some pic of my PSU upgrade in the photo folder.... and a
in the Emax is a Plus to. It even glows a cool blue!
