Yes it is, but only on an EMAX-II (unless you change it). Not on EMAX-
HD/Plus. The internal HD of an EMAX-HD/Plus has the ID set to 0. You
can remove this internal harddrive or perhaps change its ID, and then
reassign the ID 0 to an external HD if the external device allows it.
In that case you can boot from the external HD.
EMAX-HD/Plus always tries to boot from floppy or SCSI ID 0. As far as
I know the floppydrive in the EMAX (the non-EMAX-II that is) is
simply not a SCSI device...
See also the PDF files on the SCSI upgrade on www.emulatorarchive.com.
///E-Synthesist
--- In emax@yahoogroups.com, "Roger Schumann" <roger_schumann@...>
wrote:
> Isn´t the Floppy defined as SCSI 0?
> Roger
> From: esynthesist
> To: emax@yahoogroups.com
> Sent: Sunday, September 24, 2006 10:48 PM
> Subject: [emax] Re: Boot from SCSI
> As far as I know the Emax Plus can only boot from either floppy
or
> SCSI 0. So you'll need a SCSI device which can have the SCSI ID
set
> to zero. External ZIP drives can only have the ID set to 5 or 6.
> Internal ZIP drives however can have a SCSI ID set to 0 (I think).
> The EMAX-II checks the whole SCSI-chain, so if you use an EMAX-II
you
> can boot from any SCSI device.
> Maybe I am wrong about the Emax Plus, but that's what I read
about it
> and mine seems also not to be able to boot from an external ZIP
drive
> (but I don't have a lot of experience with that machine).
> ///E-Synthesist
> --- In emax@yahoogroups.com, "Alastair Gibbs" <alastair.gibbs@>
> wrote:
> > Hi Lyn,
> > Thanks for the quick response. The problem is the emax always
> looks
> > to the floppy disk drive first and I can't find the settings
where
> > you can tell it to look at the SCSI port first. Do i have to
take
> > the floppy drive out?
> > Thanks
> > --- In emax@yahoogroups.com, "Lyn Oakey" <lynoakey@> wrote:
> > > Just copy your op sys to the Zip and it should automatically
be
> > found
> > > on boot up.
> > > I have this working on both the Emax SE Plus HD and Emax II
> without
> > any problems.
> > > regards
> > > Lyn
> > > ----- Original Message -----
> > > From: Alastair Gibbs
> > > Sent: Sunday, September 24, 2006 12:15 PM
> > > Subject: [emax] Boot from SCSI
> > > Does anyone know if you can boot up from the SCSI port? I
have
> a
> > ZIP
> > > 100 drive connected with all of my samples and programs on
and
> it
> > would
> > > be convenient (and probably less noisy!) to boot up from this
> > rather
> > > than booting from a floppy every time. Is there any setting
to
> > tell
> > > the Emax where to look to boot up?
> > > Also - has anyone successfully installed an internal SCSI zip
> > drive in
> > > their machine? I might try and do this soon.
> > > Thanks
> > > [Non-text portions of this message have been removed]
