Fantastic !
I just installed the v2.5 and it works ! All requires files and
folders are included.
Many thanks.
///E-Synthesist
--- In emax@yahoogroups.com, "Dave Sotnick" <sotnickd@...> wrote:
> Ted (and E-Synthesist), you're in luck!
> I'm uploading the file SDII 2.5.sea (and why not SDII 2.7.sea) to
> files section now.
> -Dave
> On 7/27/07, ted Summers <djtbs1@...> wrote:
> > IF anyone has the full set of this 2.5 that works, I wouldn't
mind
> > having it..... I called digi a couple of years ago and said, hey I
> > have your latest protools, I understand you don't support it, but
> > can't I get an image of this or something? I'll pay.... no dice...
> > Thx,
> > Ted
> > On Jul 23, 2007, at 1:48 PM, Dave Sotnick wrote:
> > > I'm 99% sure I have these files, but I'll have to do some
digging.
> > > I'll try to get back to you soon as I know you're anxious to
get new
> > > translation features into EMXP.
> > > -Dave
> > > On 7/23/07, esynthesist <esynthesist@... <esynthesist%
40yahoo.com>>
> > wrote:
> > > > Thx Dana, but this doesn't work.
> > > > The digidesign website only provides the 2.82 version. This
is an
> > > > updater which requires that version 2.80 has been installed
> > > before...
> > > > and I don't know where to download that one :-)
> > > > Moreover I need the 2.50 files, since that's the last version
which
> > > > supported remote control of the Emax. Higher versions don't
have
> > > this
> > > > feature anymore.
> > > > Creating the folders myself is not sufficient - I tried that.
But
> > > the
> > > > folders should contain files that are part of the SDII
packages, and
> > > > I'm not able to recreate those ones (they contain the config
> > > settings
> > > > for sample rates).
> > > > ///E-Synthesist
> > > > --- In emax@yahoogroups.com <emax%40yahoogroups.com><emax%
40yahoogroups.com>, "djfiorucci"
> > > > <dfiorucci@> wrote:
> > > > > Maybe you can ind the file you need here.
> > > > > http://archive.digidesign.com/download/legacy/sd2/
> > > > > Try using Tome Viewer to extract the file you need.
> > > > > Or possibly try creating the folders yourself inside the SD
II
> > > > folder.
> > > > > I know you might have to guess what the programmer named the
> > > > folders
> > > > > but it might be worth a try.
> > > > > Dana
40yahoogroups.com>,
> > > "esynthesist"
> > > > <esynthesist@> wrote:
> > > > > > No one ??
> > > > > > Not even Rob ??
> > > > > > Any help would be appreciated !
> > > > > > ///E-Synthesist
40yahoogroups.com>,
> > > "esynthesist"
> > > > > > > Hi all,
> > > > > > > I'm trying to install Sound Designer II version 2.5 on
my Mac
> > > > > > > computer. The Mac has an Audiomedia II soundcard inside
so I
> > > > > should
> > > > > > > be able to use to software with my EmaxII samplers.
> > > > > > > I downloaded the v2.5 SIT file from this archive
(provided by
> > > > > Rob)
> > > > > > > and installed the software. So far so good...
> > > > > > > ...but when launching the SDII software it complains
about
> > > > > missing
> > > > > > > folders (SDII Sample Rates folder, SDII Fonts folder
and so
> > > > on).
> > > > > > > Indeed, these are not included in the SIT file.
> > > > > > > But they are required for running SDII.
> > > > > > > Can anyone post these folders to the Files section (or
to
> > > my e-
> > > > > mail
> > > > > > > address). It would be very much appreciated !
> > > > > > > (I need SDII to perform some tests with my EMAX
samplers in
> > > > order
> > > > > > to
> > > > > > > make a new version of EMXP with extended translation
> > > > capabilities)
> > > > > > > Many thanks !
> > > > > > > ///E-Synthesist
> > > [Non-text portions of this message have been removed]
