Emax
Re: Emax floppy and sd flash drive
2008-01-25 by ted Summers
Kurt-
If you don't have SCSI, you won't be able to use any kind of SD or CF
or anything like that.
Group----
As to the Slim floppy- I haven't had any luck with the MPF820 Slim
floppy yet. But I do have my emax apart. On the Sony MPF920-1 floppy
drive you remove the bottom cover, and move JC31 to JC30. This will
make the standard Floppy work in the emax.  Sony MPF920 is about $8
at newegg.com
Keeping in mind this is a surface mount device (actually a jumper). I
have a static safe solder station. Using a regular soldering iron
could damage the floppy controller IC..... and I have years of
experience soldering. The $8.95 solder iron bought at radio shack
may  not do the trick....and may ruin the drive.
Also note that you will have a gap in front of emax (I made a
bracket....)
YMMV
Ted
