Emax
Hard drive problems
Hard drive problems
2008-05-17 by brent
I have tried to install a zip drive
But my emax 2 can't see the drive
Tried another same thing and internal SCSI same
Tried every ID# it says hard drive not found
If I press enter anyway it says Hard ware error
I had one before and it worked then
I rely miss the speed
If any one has any suggestions I would love to here them
Thanks
Re: [emax] Hard drive problems
2008-05-17 by Lyn Oakey
A scsi Zip will only work on ID 5 or 6. Make sure you terminate the Zip.
Make sure you're connections are good - these old Emax's sometimes
need the contacts cleaning or re-plugging.
lyn
  To: emax@yahoogroups.com
  Sent: Saturday, May 17, 2008 11:58 AM
  Subject: [emax] Hard drive problems
  Thanks
Re: Hard drive problems
2008-05-17 by brent
> lyn
>   ----- Original Message -----
>   From: brent
>   Thanks
thank you LYN you are right I had it on ID#5 before and it worked
not this time and I cleaned the contacts still no go says not found
