Emax
sample dump??
sample dump??
2008-10-31 by mrdazobee
Does anyone know if the Emax can recieve sample dump info from a PC via
SDS or something similar?If so could you explain how it is done?
Thanks...
Re: sample dump??
Sorry I forgot to say it is the Emax 1.
via
> Thanks...
Re: [emax] Re: sample dump??
2008-10-31 by Mike Wolak
I think I remember someone saying it works using the standard midi sds in Soundforge. In order to use the high speed serial port you'll need an old Mac and Alchemy or Sound Designer with a custom cable.
--- On Fri, 10/31/08, mrdazobee <mrdazobee@...> wrote:
> From: mrdazobee <mrdazobee@...>
> Subject: [emax] Re: sample dump??
> To: emax@yahoogroups.com
> Date: Friday, October 31, 2008, 11:49 AM
> info from a PC
> via
> it is done?
> > Thanks...
Re: [emax] sample dump??
2008-11-01 by Michael Wisbech
Emax - PC : MIDI in / out
don't remember exactly; but on the Emax. i think 'sys.excl' should be set
to 'send & recieve'.
>Thanks...
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.4/1754 - Release Date: 29-10-2008
2008-11-01 by tu@...
The Emax can receive sample dumps via MIDI SDS according to the Emax OS v3.0 MIDI spec.
However, note that the first and last sample of the data should be padded with zeros. The Emax
also expects 12 bit linear samples, which it presumably converts into 8 bit compressed form to
store in memory. I am not sure what it would do with 16 sample data. There are also some issues
to do with handshaking, sampling rates, sample placement and loops etc.
It looks like the fast sample dump via RS422 uses a slightly modified form of the SDS dump that
allows more compact packing of the 12 bit samples and thus even faster transfer.
/Tristan
Thanks...
Re: sample dump??
2008-11-01 by mrdazobee
Thanks for the replys.Could you explain further what "padded with
zeros" means?I was going to use the "Awave" program that converts SDS
to 12 bit so that should be fine.Have you achieved a sample dump via
midi yourself?If so could you give some info on how you did it,or
point me to where the process may be explained further?
etc.
faster transfer.
> /Tristan
via
> Thanks...
2008-11-02 by John Silveria II
This is how far I have fallen behind the gear curve. I use my Emax SE HD
(when I had it) and my Emax II (which I still use) exclusively with MIDI
SDS through my old version Sound Forge (Sound Forge 2.xx I believe). The
Emax does indeed work fine with SDS and I have a small guide on my site
(and maybe in the Files section) that explains the Offset procedure that
has to be used since the Emax II manual has incorrect assignments for
SDS. Besides Sound Forge, and I think Recycle, I believe I have also
used Awave and the old DOS program Samplitude with my Emax and Emax II
http://www.silveriafamily.com/emax/midisds.html
> Thanks...
                      Yahoo! Messenger: EmaxJS
The Silveria Family Website and Emax and Emax II User's Group
Re: sample dump??
2008-11-02 by mrdazobee
I noticed the tutorial on your site although I thought it only
applied to the Emax II.Does the same proceedure apply to the Emax I?
SE HD
MIDI
believe). The
site
that
for
also
II
PC via
> > Thanks...
2008-11-03 by John Silveria II
I haven't had my Emax SE HD for about 10 years, but I believe I wrote
the guide knowing that it would work with both. I don;t believe the
Offset is needed though.
2008-11-03 by tu@...
I have not actually used MIDI SDS to dump samples to an Emax, I was just reading from the V3.0
MIDI specification on the Emulator archive.
I believe the padding refers to adding a single extra sample before the first and after the last
sample of each sound when dumping. According to the spec these extra samples should have the
value of zero. I don't know why or if it is really required but that is what the spec says.
You can always try a dump and see. I believe the Emax can only be the target of SDS dumps or
requests from external devices. SDS dumps cannot be initiated from the Emax front panel.
/Tristan
Quoting mrdazobee <mrdazobee@...>:
> etc.
> faster transfer.
> > /Tristan
> via
> > Thanks...
Re: sample dump??
2008-11-04 by Rudi
via
> Thanks...
SDS works...
but... why don't you take EMXP to transfer *wav-files into an Emax?
It's much faster than sample-dump!
