Need SE upgrade disc image for EMXP
2008-12-07 by Richard
I want to upgrade my Emax to a SE version so I need the SE upgrade disc image for EMXP, anyone have it? The one in the files section does not work in EMXP.
2008-12-07 by esynthesist
Rich, EMXP only allows sound bank and operating system files, not special purpose disk images from Emu. No problem however: the EmaxSEUpgrade.zip file in the files section can be copied to a disk with the OmniFlop software itself. Make sure you have a blank Emax formatted floppy disk (either formatted by the Emax or by OmniFlop). Then start the OmniFlop wizard and select "write disk", unflag the "automatic detect" and select the 80*2*10*512 Emax standard disklayout from the list. (you have to do the same thing if you have to format the disk first). Select the unzipped SE upgrade disk image as a source file and start the write process. If this is the very first time you're using Emax disks with OmniFlop, the software will ask you to get a free license first. But this takes only a few seconds... ///E-Synthesist --- In emax@yahoogroups.com, "Richard" <rish@...> wrote: > > I want to upgrade my Emax to a SE version so I need the SE upgrade > disc image for EMXP, anyone have it? The one in the files section does > not work in EMXP. >
Ok got it working thanks E-Synthesist --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote: > > Rich, > > EMXP only allows sound bank and operating system files, not special > purpose disk images from Emu. > No problem however: the EmaxSEUpgrade.zip file in the files section can > be copied to a disk with the OmniFlop software itself. > > Make sure you have a blank Emax formatted floppy disk (either formatted > by the Emax or by OmniFlop). Then start the OmniFlop wizard and > select "write disk", unflag the "automatic detect" and select the > 80*2*10*512 Emax standard disklayout from the list. (you have to do the > same thing if you have to format the disk first). Select the unzipped > SE upgrade disk image as a source file and start the write process. > > If this is the very first time you're using Emax disks with OmniFlop, > the software will ask you to get a free license first. But this takes
> only a few seconds... > > ///E-Synthesist > > --- In emax@yahoogroups.com, "Richard" <rish@> wrote: > > > > I want to upgrade my Emax to a SE version so I need the SE upgrade > > disc image for EMXP, anyone have it? The one in the files section > does > > not work in EMXP. > > >
