emax 1 "crc data error"
2009-01-18 by grom
2009-01-18 by grom
> hi > i m jerome > i have an emax 1 > i try to load floppy but it doesn't work... > > i have this message error " crc data erro" > > does it mean that i have to change my floppy drive? > > what kind of drive do i need to replace mine > > thanks a lot > > > grom >
2009-01-18 by jammie.emma
--- In emax@yahoogroups.com, grom <jerome@...> wrote: > no its the floppy disk thats at fault the crc is for checking the data on disk to see if it matches the crc data table if it is corrupted it will come back as a crc error. get a new ddsd disk format it and use emxp to write an image to it and check the new disk
> > hi > > i m jerome > > i have an emax 1 > > i try to load floppy but it doesn't work... > > > > i have this message error " crc data erro" > > > > does it mean that i have to change my floppy drive? > > > > what kind of drive do i need to replace mine > > > > thanks a lot > > > > > > grom > > >
2009-01-18 by grom
hi thanks for the response do you know where i can download an OS for my emax on the internet so i can write it on a new floppy ? best grom Le 18 janv. 09 à 15:21, jammie.emma a écrit : > --- In emax@yahoogroups.com, grom <jerome@...> wrote: > > no its the floppy disk thats at fault the crc is for checking the > data > on disk to see if it matches the crc data table if it is corrupted > it will come back as a crc error. > > get a new ddsd disk format it and use emxp to write an image to it > and check the new disk > > > > hi > > > i m jerome > > > i have an emax 1 > > > i try to load floppy but it doesn't work... > > > > > > i have this message error " crc data erro" > > > > > > does it mean that i have to change my floppy drive? > > > > > > what kind of drive do i need to replace mine > > > > > > thanks a lot > > > > > > > > > grom > > > > > > > > [Non-text portions of this message have been removed]
--- In emax@yahoogroups.com, grom <jerome@...> wrote: > there should be an emp format os images in the file section get it get the emxp program also in the files section load os in emxp and write image to floppy
> hi > thanks for the response > do you know where i can download an OS for my emax on the internet > so i can write it on a new floppy ? > > best grom > > > > Le 18 janv. 09 à 15:21, jammie.emma a écrit : > > > --- In emax@yahoogroups.com, grom <jerome@> wrote: > > > no its the floppy disk thats at fault the crc is for checking the > > data > > on disk to see if it matches the crc data table if it is corrupted > > it will come back as a crc error. > > > > get a new ddsd disk format it and use emxp to write an image to it > > and check the new disk > > > > > > hi > > > > i m jerome > > > > i have an emax 1 > > > > i try to load floppy but it doesn't work... > > > > > > > > i have this message error " crc data erro" > > > > > > > > does it mean that i have to change my floppy drive? > > > > > > > > what kind of drive do i need to replace mine > > > > > > > > thanks a lot > > > > > > > > > > > > grom > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
