Emax
emax2 to esi midi dump
2009-02-27 by sparkyscorp
Hi gang,Im having trouble preforming a midi sample dump to an esi
sampler from a emax2.The emax2 requires a transmit midi message to
dump Ive hit enter to start the dump on the esi but nothing happens? HELP1
Re: [emax] emax2 to esi midi dump
2009-02-27 by mr julian
Are they meant to be compatible this way???
I think ESI32 will load emaxII disks. didn't think you could dump sounds
between them.
if it actually is meant to work, how did you connect the MIDI cables?
