Emax
Something's wrong with my Emax sound library, please help!
2009-03-05 by bermudaben2006
Hi there,
I hav a BIG problem with my Emax.
I bought it on Ebay with just a few disks. These are working fine.
Lately I downloaded all Emax factory sounds (xxx.em1 files) from a site on the Web. In addition, I downloaded the EMX DOS program in order to copy the sound files from my computer to disks previously formatted with my Emax.
While I am able to copy the .em1 files from my computer onto my Emax disks, the presets don't play correctly once loaded into Emax. Some presets don't play at all, the others sound like very badly looped, kind of stuttering...
I would be very grateful if someone could point me to where the error could be. I am using DD disks that were originally formatted for an Amiga computer. They seem to be ok. When I copy presets from the disks that came with the sampler to one of them they work fine.
How am I supposed to use the EMX program? I open a DOS window and run the program, right? Or do I need to start the computer in DOS mode? I noticed that EMX displays an error message when I choose "verify disk". It says: "Block 79. Verify Error". But it does this with all disks, also with the ones that are working correctly on Emax.
I appreciate your help.
Ben
Re: [emax] Something's wrong with my Emax sound library, please help!
2009-03-05 by Ted Summers
Everytime I use EMX I always boot from DOS, I do NOT use it in a window
under XP / 2000/ Vista.
Ted
On Thu, Mar 5, 2009 at 11:55 AM, bermudaben2006 <bermudaben2006@...>wrote:
>   Hi there,
> Ben
2009-03-05 by Brooks Mosher
why not try using the EMXP program which can run on Windows?
that might be a better way to go...
On Thu, Mar 5, 2009 at 1:55 PM, bermudaben2006 <bermudaben2006@...>wrote:
>   Hi there,
> Ben
2009-03-06 by Brian Ronn
Hi Ben
You need to run EMX in pure DOS mode. A DOS box in windows mode creates errors.
Best regards
Brian
Denmark
--- Den tors 5/3/09 skrev Brooks Mosher <brooksmosher@...>:
Fra: Brooks Mosher <brooksmosher@...>
Emne: Re: [emax] Something's wrong with my Emax sound library, please help!
Til: emax@yahoogroups.com
Dato: torsdag 5. marts 2009 21.53
On Thu, Mar 5, 2009 at 1:55 PM, bermudaben2006 <bermudaben2006@ yahoo.de>wrote:
> Hi there,
> play at all, the others sound like very badly looped, kind of stuttering.. .
> Ben
      Trænger du til at se det store billede? Kelkoo giver dig gode tilbud på LCD TV! Se her http://dk.yahoo.com/r/pat/lcd
Re: Something's wrong with my Emax sound library, please help!
2009-03-06 by bermudaben2006
Yeah I just found out about the EMXP program yesterday! I'm gonna try and install this program today. I thought EMX was the only solution...
Thanks!
> >   Hi there,
> > Ben
Right...I didn't know that. Does anybody know if using an external USB floppy drive can also cause problems with EMX? I don't have an internal floppy drive...maybe I should install one?
--- In emax@yahoogroups.com, Brian Ronn <brian_ronn@...> wrote:
> Hi Ben
> Best regards
> Brian
> Denmark
> > Hi there,
> > Ben
2009-03-07 by bermudaben2006
--- In emax@yahoogroups.com, "elmbeatz" <elmbeatz@...> wrote:
> E-Synthesist, the official E-Mu God, points out that EMXP does NOT work properly with an external floppy drive.
Yes I read that. But I wasn't sure about the old EMX software. Anyway, I have installed EMXP and an internal floppy drive now and everything is working perfectly. This software is awesome. E-Synthesist is a genius.
