Emax
Can the Emax1 adress more than one Scsi drive ?
2009-03-29 by marc
I would like to copy my Internal Miniscribe HD to my ZIP drive, is it possible to do that ?
I am not sure if the Emax can handle more than one drive at the same time..
If i mount a Zip drive, which SCSI id should i give it ? Termination on/off ?
thanx
Marc
Re: [emax] Can the Emax1 adress more than one Scsi drive ?
2009-03-29 by Dave Sotnick
Yes, it's definitely possible to copy from one HD to another. You'll
need the Plus OS, and in the "Special" module you'll find a "Copy HD"
option.
Since the Internal HD is ID#0 on the SCSI chain, assign the ZIP drive
any number between 1 and 6. If the ZIP is the last device on the SCSI
bus, you'll need to make sure to enable termination at the end of the
chain (on the ZIP).
-Dave
> thanx
> Marc
