To: emax@yahoogroups.com
Sent: Tuesday, April 28, 2009 2:06:29 PM GMT -06:00 US/Canada Central
Subject: [emax] Re: Emax II Floppy Issues
Hi Jammie,
Thanks for the reply. I think the flat connector had a little notch/nose and will fit only one way. Or am I wrong? I will have to open it up and again and check. Thanks.
G.
--- In emax@yahoogroups.com, "jammie.emma" <jammie.emma@...> wrote:
> --- In emax@yahoogroups.com, "George" <trickstar303@> wrote:
> check that the blue line on the ribbon cable is lined up with pin 1
> if the cable is back to front then you will have the signals to the floppy the wrong way round which would indicate the disk not formatted error
> > Hi,
> > I posted here a few days ago regarding my floppy drive issues. I would get a "Disk not Formatted" error when trying to load the original library disks. Today I opened the unit up cleaned the floppy head with alcohol. I noticed when I opened it that the flat floppy cable wasn't plugged all the way in and thought that might have been the reason for the errors I was getting. But after I put it all back together, all I'm getting now immediately upon powering the unit on (even without a disk in the drive) is the "Disk not Formatted" error. By the way, I also have a Rack Version Emax II that is doing the exact same thing. So basically, when powering the unit up, I get the blinking "Disk not Formatted" error along with a clacking Floppy noise. Does anyone know this problem and what can be done? Thanks in advance for any help.
> > George
http://www.silveriafamily.comYahoo! Groups Links
