Emax
SCSI kits available / installation available.
2009-05-13 by Ted Summers
Add SCSI capability to your Non-SCSI Emax 1.
I currently have 10 kits available.
Emax logic PCB Rev (version) 2 and 3 can be upgraded. Rev 1 boards cannot be
upgraded.
A rev 3 board will require no modifications of the logic board. Easily Do it
yourself!!!!
A rev 2 board needs modified.
Each set of chips will be tested in my Emax to verify operation prior to
shipping.
Kit includes:
IP379a PAL
SCSI Capable EPROM (boot prom)
AM5380PC SCSI Controller
28-pin socket for the EPROM
Wire-wrap wire for the necessary modifications.
50-pin SCSI internal ribbon cable (non-terminated).
HD-capable Emax OS disk (either SE or Non-SE... please specify when ordering
in your paypal comment).
Each kit is $50.
Shipping in the US is USPS priority mail. Up to two kits is $7.25 for
shipping.
International Shipping varies.
I take paypal. djtbs1 (at) gmail.com
The kit does not include-
HARD DISK /SCSI Drive
"external SCSI adapter board" / or external connector- but external
connectors are readily available from many sources (ebay or online).
A mounting plate to mount the HD (make one from sheet metal or steel, etc) -
or a 5 1/4 to 3 1/2 in drive bay converter kit / rails may work for this
purpose also.
A power splitter - I am not including this as I have different reports as to
whether this is needed for all emax.
Some Emax units already have a power cable for a hard drive. Both of my Emax
did.
This kit has been successfully used with:
SCSI Zip
SCSI Compact Flash
SCSI hard drive
IDE CF (works via an ACARD SCSI adapter.....)
The modifications are not extremely complicated.
You need to be reasonably skilled with a soldering iron to perform the
modifications.
I am not responsible for failed modifications performed by you to your logic
board.
If you are in doubt as to whether you can successfully install the kit, I
will install the kit onto the Emax logic board for an additional $50
+shipping
This includes:
SCSI chipset kit
Installation Labor
Verification of floppy and SCSI boot.
OS Floppy
Internal SCSI cable.
Installation for Emax Rev 2 boards only.
Working boards only.
So an installed kit is $100 + shipping.
Please note that the cost for Non-US destinations may be expensive for
shipping a logic board with insurance....
Research the shipping costs if outside the US before contacting me for
installation services.
Upon receipt of an Emax board, I will test that the board boots and appears
to work properly.
If the board does not succeed boot test, I will send it back and not attempt
installation.
In that event, money would be refunded minus the return shipping cost.
Ted Summers
Springfield, OR USA
Re: [emax] SCSI kits available / installation available.
2009-05-25 by ss
My God, Michael!  If it is I'm leaving it for Jammie without a doubt
and I'm heading for the nearest pub
with Mickey Rourke as quickly as possible!  LOL!!
On second thought, perhaps we should BOTH GO to the nearest pub -- and
take Jammie with us!
What do you think about that...?
If we're lucky we'll run-into Kate Winslet there and never think of
Emulator equipment again!  :-)
Jammie, are you all right old man?  ;-)  :-)
On 25 May 2009, at 13:57, Michael Wisbech wrote:
> Hi Ted
> Is this the instructions for the SCSI set ?
> http://www.emulatorarchive.com/assets/PDF/Emax%20Plus%20SCSI%20Retro%20Instructions.pdf
- This communication is confidential to the parties it is intended to
serve -
Truth does not fear investigation.
"There are no secrets that time does not reveal."  -- Jean Racine (1669)
2009-05-26 by Ted Summers
Yes. That is it.
Ted
On May 25, 2009, at 1:57 PM, Michael Wisbech wrote:
Hi Ted
