Subject: Re: [emax] Stereo sample phase reversal?
To: emax@yahoogroups.com
Date: Saturday, August 29, 2009, 11:05 PM
The correct Y-cable works, of course. I had no idea that that was how balanced outputs work, so hence the error.
D.
Hello Daniel,
I would say the output of your soundcard is balanced TRS, where the
tip and ring carry the same mono signal but with inverted polarity.
However, the Emax II sampling input uses the tip and ring of the TRS
plug as unbalanced left and right signals. So when you sampled in
stereo you were not getting stereo, just normal and inverted mono
signals. If you want to sample in stereo with your present cable then
try plugging into a stereo TRS output like a headphone socket.
Otherwise you will need a Y adapter plugged into the Emax II sampling
input so you can connect it to separate left and right unbalanced mono
signals.
Tristan
Saturday, August 29, 2009, 6:59:19 PM, you wrote:
DB>
DB> Hi all,
DB> Something wierd happened while I was recording with the Emax II
DB> and I'd really like to understand why.
DB> Here is the setup I used (I suspect this is the problem)
DB> The bass and flute parts are homemade samples. They are stereo
DB> samples, but they were sampled from a mono source. - a single
DB> output on my soundcard. The used a stereo cable running from a
DB> single output of the soundcard to the stereo in of the Emax II,
DB> and sampled in stereo. When I later recorded the bass line of the
DB> music, I recorded it in stereo, and it came out with the phase of one channel reversed:
DB> http://www.type34. info/temp/ My%20Composition s/basswave. jpg
DB> I would have expected the two channels to be identical. Does
DB> anyone have any idea why this happened?
DB> Thanks,
DB> Daniel
DB> [Non-text portions of this message have been removed]
DB>
DB> Messages in this topic (1) Reply (via web post) | Start a new topic
DB> Messages | Files | Photos | Links | Database | Polls | Members | Calendar
DB> Emax and Emax II User's Group Website
DB> http://www.silveria family.com
DB>
DB> Change settings via the Web (Yahoo! ID required)
DB> Change settings via email: Switch delivery to Daily Digest | Switch format to Traditional
DB> Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe
DB> Recent Activity
DB> 2
DB> New Members
DB> 1
DB> New Files
DB> Give Back
DB> Yahoo! for Good
DB> Get inspired
DB> by a good cause.
DB> Y! Toolbar
DB> Get it Free!
DB> easy 1-click access
DB> to your groups.
DB> Yahoo! Groups
DB> Start a group
DB> in 3 easy steps.
DB> Connect with others.
