OK- well you definitely wouldn't want a jumper on 4. That means a
specific command must be sent down the SCSI bus to start the drive up.
A lot of times the jumpers on the front are duplicate of the SCSI ID
and termp power jumpers. but it varies by drive.
You would really want to know what those are for before you start
jumpering them.
Ted
On Oct 31, 2009, at 3:44 PM, thenewyorkcowboy wrote:
YES there are!
I opened the drive to look and there is a main sticker with the set of
jumpers that goes like this:
1: Disable SCSI Terminators
2: Option Link 1
3: Option Link 2
4: Enable Waitspin
5: SCSI ID 1
6: SCSI ID 2
7: SCSI ID 4
Since I had no idea what the OPTION jumpers are for, I jumpered them
one at a time and then both.
Only 'Option 2' on #3 Jumper made any difference by itself and not in
concert with the Option 1 jumper. When option 2 is connected the
EMAXII immediately sees the drive, it is not listed as "NOT FOUND" at
all now ever. It comes right up. Any ideas what that Option is? Parity
maybe? Narrow or Wide? I dunno.
There is also a set of jumpers right at the front of the drive near
the LED without any markings at all on the PCB, a set of 5. Those may
be similar to any number of SCSI drives I have had in my possession
throughout the years, so no telling what they do but I suppose I could
jump them as well, one by one, I just would not want to burn out the
LED light or short the alternate LED jumper if there is one of those.
Very similar to this diagram:
http://www.pcguide.com/ref/hdd/op/jumpSCSI-c.html
I am putting it down for tonight and am going to leave the jumper on
the Option 2 as it was an improvement. Later I will use an active
terminator and see if that helps with the drive termination disabled.
--- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> No idea- are there any additional jumpers on the NOMAI inside or
out????
> Glad I could help with the TERM issue though.
> Regards,
> Ted
> On Wed, Oct 28, 2009 at 9:01 AM, thenewyorkcowboy <
> thenewyorkcowboy@...> wrote:
> > Hey Ted,
> > Well they say writing is therapeutic and after writing that
dissertation I
> > figured I had better recheck what I thought all the way down the
cables.
> > I did find that I had the ZIP insider SCSI termination jumper on
and the ID
> > set to 5, so I changed this arrangement to OFF and ID 6 and then
at that
> > point the entire chain was visible to the EMAX II. So my present
arrangement
> > is:
> > EMAXII ----Conner (ID#1) ----- ZIP INSIDER (ID#6) ----- NOMAI 750
MCD
> > (ID#5) ----- ACTIVE TERM.
> > In my experience I have always thought that any terminator that
has an LED
> > is Active and those that don't have no LED. I only have one
terminator each
> > that actually 'state' on the terminator that they are active or
passive, and
> > they both have the LED/NO LED respectively. The others simply
either have an
> > LED or don't, and I have a couple that are marked TERMINATOR, and
they are
> > actually "pass through" meaning I can put them on the Centronics
connector
> > and still put a cable on the other end....interesting..
> > So at this point I was more confident that the EMAXII at least
had no ID
> > errors, and I went ahead and successfully formatted 5 ZIP100
cartridges as
> > well as copied the software to them from the Conner.
> > But even in this arrangement now, the EMAXII does not fail in
recognizing
> > the NOMAI at any time as it did before but it will still give me
the message
> > SCSI: HARDWARE ERROR upon trying to format the NOMAI cartridges.
> > I searched high and low on the internet and found that the NOMAI
drives are
> > SCSI-2, and also found this reference on the Adaptec site:
> > http://www.adaptec.com/en-US/support/scsi/2930/AHA-2930CU/use_prod/scsi_terms.htm
> > Which is leading me to believe now that the ZILOG Z0538001PSC
SCSI chip
> > inside the EMAXII is incapable of either A: telling the NOMAI
drive to 'step
> > down' to SCSI-1 speeds in timing as a normal PCI controller could
in a
> > computer, or that B: the NOMAI drive is NOT backwards compatible
with SCSI-1
> > controllers at all and has all of its timings fixed so that the
data
> > handshakes and such are 'too fast' for the EMAXII to assimilate
as with all
> > the formatting I've done, the EMAXII always displays 'verifying'
which would
> > indicate that during formatting there is some CRC going on or
similar that
> > is being missed by the timing in the Zilog chip as being 'too
fast', similar
> > to why so many CD-ROM drives do not work with the EMAXII because
they feed
> > data at above the data rate of the EMAXII or have been designed
for SCSI-2
> > timings (most known compatible CDROMS are 1x or 2x speed) even
though they
> > have a 50pin connector. This is another mini project of mine as I
have an
> > old SCSI 2x CDROM that uses the caddy made by TOSHIBA, but I've
never gotten
> > the EMAXII to even identify the drive. Maybe I'll try some more
with my 'new
> > knowledge'.
> > Anyone know any way of 'slowing down' something designed for
SCSI-2 specs
> > to SCSI-1 timings, besides a 25 foot cable?
> > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, Ted Summers
<djtbs1@>
> > wrote:
> > > With the type of configuration you have, have you:
> > > checked for termination jumpers on the drives?
> > > Since you are using a terminator (w/green light), no drives
should
> > > have termination.
> > > It should go:
> > > emax ----- conner (id#) ---- next SCSI ID #--- TERM.
> > > But if term power is on for any of the drives it will mess up
the chain.
> > > also- is that an active or passive terminator?
> > > how long are the cables?
> > > Regards,
> > > Ted
> > > On Oct 27, 2009, at 1:08 PM, thenewyorkcowboy wrote:
> > > Greetings All,
> > > I have an EMAX II 4mb (2212) with the original factory installed
> > > external SCSI connector (black and to the rear and left of the
volume
> > > slider.) I am using OS 2.14 and the floppy works fine. I also
have an
> > > external SCSI Conner drive CP-30540 'hard set' to SCSI 1 and
actively
> > > terminated with a terminator that has the green light on it when
> > > working properly. I have been able to format and use this
Conner drive
> > > fine without ever any problems.
> > > My problem is every other device I own. I have two different
SCSI Zip
> > > Drives (1 external with the ID 5/6 switch, and 1 internal set
to ID 5
> > > mounted in a dual external case with the Conner drive, and a
pretty
> > > hefty power supply.) I just purchased an external SCSI NOMAI
750.C and
> > > two 540mb cartridges, this device has the 25pin SCSI cable
exactly
> > > equal to the EMAX II connector. It can also be set to ID 1 or
5. I
> > > also have 4 different 25-25 cables, as well as probably a dozen
> > > 25-50cn cables I have tried out on all the various setups. I
also have
> > > several different 50pin SCSI CD Roms I have tried as well with
a EMXP
> > > formatted CD. Just throwing this info in as I can be certain it
is NOT
> > > the connecting cable in any fashion, as I've tried like 10
different
> > > cables in all various arrangements and I am frustrated.
> > > I power up the external devices and wait until they go through
their
> > > initialization before I turn on the Emax II. Here's my problem:
> > > ONLY SPORADICALLY will the Emax II ever identify the 'type' of
drive I
> > > am using, such as IOMEGA ZIP 100, and NOMAI 750 MCD. USUALLY
the Emax
> > > II displays SCSI # NOT FOUND, and occasionally as well will
display
> > > NOT EMAXII DRIVE.
> > > On the rare times I can get the drive to be at least 'named', I
go
> > > ahead and try to FORMAT it and have even tried to simply COPY
SOFTWARE
> > > to the drive as I read in other literature (EII, EIII) that ZIP
drives
> > > require a special way of 'formatting' by just copying over the
> > > software. In short I have tried everything I know and even the
> > > diagnostics (3629) to find out what is going on with these
drives but
> > > no joy. I ALWAYS GET "SCSI HARDWARE ERROR" flashing along with
> > > ENTER light flashing.
> > > Basically the Conner works fine but my Emax II does not like
any other
> > > device I own, no matter how I hook it up, select the ID, or do
> > > anything with them, and I know that many combinations of hardware
> > > cannot be 'bad' to give "SCSI HARDWARE ERROR" all the time.
> > > My 'only' thought on this matter is that the ZIP cartridges and
> > > NOMAI cartridges since they are formatted to MAC/PC
respectively among
> > > them have some kind of file system error that will not allow
the EMAX
> > > II to do it's format job on them.
> > > If I couldn't get the Conner to work either I would swear it is
> > > definitely something wrong inside the EMAX II like the SCSI
CHIP, but
> > > the fact that the Conner works fine but nothing else does is
what is
> > > throwing me. Any help out there?
> > > Kirk
> > > [Non-text portions of this message have been removed]
