To: emax@yahoogroups.com
Sent: Wed, December 30, 2009 2:34:57 PM
Subject: [emax] Re: Flip LCD?
In the Emax I, the trimmer is present in some revisions only.
Note I have two equal boards (Version 2 Rev C), but both have differences. ONe has the trim, not the other. One have the E chip in a daughterboard, other not, even being the same revision.
--- In emax@yahoogroups. com, tu@... wrote:
> 1. There is also a trimmer on the front panel of the Emax rack II that adjusts the viewing angle of
> the LCD. I believe the Emax I rack also has this. It is inside a small hole near the data slider.
> Gently inserting a small, flat blade screwdriver and adjusting this may improve the contrast of the
> display at your viewing angle.
> /Tristan
> On Wed, Dec 30th, 2009 at 10:53 AM, Ted Summers <djtbs1@...> wrote:
> > 1. A replacement LCD may have a wider viewing angle, something to
> > consider....
> > 2. If the data slider when you save a bank is all the way down, it
> > should be
> > on floppy, or type 00, should set it to save to floppy.
> > Regards,
> > Ted
> > On Tue, Dec 29, 2009 at 3:18 PM, Per <perbroberg@ ...> wrote:
> > > Hi all
> > > Got two questions someone here maybe can answer:
> > > 1. Is it possible to do something about the LCD? I have a rackunit
> > placed
> > > above the computerdisplay and there the letters are quite faded.
> > The
> > > viewingangle is below what it's designed for. Is it possible to
> > turn the LCD
> > > (without getting the letters upside down) or is there another
> > better
> > > solution?
> > > 2. My HD broke down. It's a Emax HD SE running Emax Plus 1.0. How
> > do I make
> > > the machine disregard the HD when I want to save to floppy? Now it
> > only says
> > > HD error - or something like that - and then exits the
> > savefunction.
> > > /PBIT
> > [Non-text portions of this message have been removed]
> > Emax and Emax II User's Group Website
> > http://www..silveriafamily.comYahoo! Groups Links
