Memory Management problems?
2010-05-03 by nsputnik
I have a problem with my Emax. When I assign and sample the first sound, everything is fine. When I assign and sample the 2nd or 3rd sound, for some reason the key assignment jumps up to a key several octaves up along with the pitch. If I delete this sample, sometimes it deletes parts of the other sounds I have sampled, and some keys will now contain more than one of the sampled sounds. It is like a game of wack-a-mole. I can keep sampling new sounds, sometimes it takes correctly, sometimes it does not sample, sometimes a previously sampled sound will get messed up with pieces in the sound missing. Is this a software bug, a hardware failure? Is this a known problem in one of the OS versions? I am not with it right now so I can't see what the software version is. Somehow I managed to fill an entire bank of very short drum sounds (0.5 sec) while bearing with this problem and not have the problem on any keys. Now I am trying to do 3.5 second drum loops and it seems the longer the sound, the less forgiving. Saving on a floppy.
