Emax
I need a esi library sitar sound thats been converted to wav or the emax2 one
2010-08-29 by sparkyscorp
Hi gang,Im trying to get my esi library cd roms into a korg triton.In particular the sitar sound.My emax2 has a great one too on its HD.Ive done some googling around and it seems sooooo complicated.....has anybody got one thats been converted to wave,AIFF or Akai s1000 format they could email me or can you demystify the waters?thanks,Mark
Re: [emax] I need a esi library sitar sound thats been converted to wav or the emax2 one
2010-08-29 by jammie
what esi disk is it on  i can do a wave of it keymaps or better still i can make it into a triton object
  To: emax@yahoogroups.com
  Sent: Sunday, August 29, 2010 8:33 PM
  Subject: [emax] I need a esi library sitar sound thats been converted to wav or the emax2 one
  Checked by AVG - www.avg.com
  Version: 8.5.441 / Virus Database: 271.1.1/3100 - Release Date: 08/29/10 06:34:00
Re: I need a esi library sitar sound thats been converted to wav or the emax2 one
great....Im at a loss to find my cdrom cable...give me a while to find it,though after reviewing the cd roms Im sure it is on Formula 4000 earth tones....which bank Im not sure but I think there is only one labeled sitar.Triton format would be awesome...Im off to play the summers end fest in England soon and this would cut down on gear....what program are you using?
>   ----- Original Message -----
>   From: sparkyscorp
also my emax2 has a great sitar sound with tablas down in the bass region...I have no idea where that came from as it was in it when I bought it.
>   From: sparkyscorp
Re: [emax] Re: I need a esi library sitar sound thats been converted to wav or the emax2 one
i have the formula4000 earth tones cdrom so its not a problem just stick it in translator and make a triton file for you i will have to email it to you
  Sent: Sunday, August 29, 2010 9:13 PM
  Subject: [emax] Re: I need a esi library sitar sound thats been converted to wav or the emax2 one
  > From: sparkyscorp
its the same sound on tthe 4000 cdrom its from the e2 soundset and is used in most of the emu sound modules aswell they were converted by emu from the e2 to the e3 using sounddisigner2 software then sample dumped to the e3
i have all the e2 library aswell as the emax1/2 library and most of the library in the emax1/2 are of the e2 sample sets
  Sent: Sunday, August 29, 2010 9:15 PM
  > From: sparkyscorp
2010-08-30 by sparkyscorp
Hi,thank you so much for answering the call.Tell me what program do I need to do what you are doing?Is translator the name?Id love the emax2 sample as well as the esi file in triton speak....though Id really like to be self sufficient.Just trying to open a emu cdrom in windows is impossible...it doesnt recognize the emu Os or file type....EMXP doesnt seem to recognize the esi stuff....any advise would be awesome...my email is sparkyscorp@...m
>   From: sparkyscorp
>   > From: sparkyscorp
2010-08-30 by jammie
chicken systems translator can trans late to triton
extreme sample convertor can read any emu image from e3 onwards to eos  it can translate to many formats i use it for soundfonts mostly ans wusic format banks and emulatorx
  Sent: Monday, August 30, 2010 1:34 AM
  > From: sparkyscorp
  > > From: sparkyscorp
2010-08-30 by mark sherkus
hi,Ive dwnlded translator and am trying to make it work.Is a ksf file the one that the triton uses?Is that korg sampler format?Im going to experiment....on this 2.9 version it doesnt neccesarily behave as the manual explains...but I think I got it to convert to a korg file.Then what? burn  to a regular data burn or should I burn an image....do I need to format the media its going to first or will it just see the files and understand them?I geuss I could hook up the triton to the scsi pci card on my computer though I dont think the triton will see the computer ssystem so Id be better off making a disc right?....thanks for the help...Ill keep trying here,Mark
